04-25-2020, 11:53 AM | #1 |
12
Rep 52
Speedo coding not working
-So my speedo reads 3kph fast. Going 110kph is really 107kph.
-I was told many times, just code it out, so I tried but still the same. -'analog' speedo is still 3kph fast, hud speedo 2kph fast, they use to match -setting cruise runs off 'analog' so 110kph is 107 gps, 109 hud -only changed BC_V_KORRECTER to not active -what do I need to do to fix analog to hud speed, and better correct speedo vs gps? im using bimmercode, been trying to find the answer the last 3 days - running stock tires - I wish it was as easy as it is in my Ford to code.
2016 435i xdrive
2014 235i - traded |
04-25-2020, 01:10 PM | #2 |
588
Rep 2,302
There has to be a reason why this happens.
If you have already changed BC_V_KORREKTUR, it can only be due to the tires. You are sure that it is the right size? |
