Parasitic Battery Drain?
04-23-2020, 06:40 PM | #1 |
Chief Mambo
24
Rep 46
Newbie to the diesel world here. I'm wondering if anyone can tell me the typical parasitic draw on a battery when the car is not running and is 'asleep'. On my recently acquired 335d which has a new factory battery, my BatteryTender 1.5A trickle charger(s) will never fully charge the battery and go into 'float' state where it just monitors the charge. I tried two of the BatteryTenders, and I also tried a larger / older 2A trickle charger, and no go on any. This is after 2-3 days of charging, and, the battery was not dead, and the car had been run for over an hour at highway speed. I'm thinking the parasitic draw on the battery has to be greater than 2A since the charger never catches up. Every other vehicle I use the trickle charger on usually is fully charged and floats after less than 24 hours. Anyone have any data?
Thx, Ron
2021 X5 M50
2016 M240iRacing |
04-24-2020, 07:42 AM | #2 | |
230
Rep 550
Drives: 2018 M5 / 2011 X5 35d
04-24-2020, 09:57 AM | #3 | |
274
Rep 1,054
Another issue could be the alarm siren. If the battery within it starts to degrade it will pull from the main battery. Do you have any bmw scan tools? You can request a "shutdown mode" which will force everything to power down. That's a place to start. Chasing electrical draws is very tricky in these cars. I had one in my x5d, it was so bad that one night in the cold Maine weather and the battery would be completely dead. Took out the frm module. Turned out to be a pinched roof drain hose on the rear passenger side, it was like this since it was built!!! I had 4" of water in my trunk on one of the side cubbies sloshing around getting water all over connectors and my battery. Replaced the drain hose and the connectors on the TCM and bam draw was eliminated. Oh and I use a CTEK charger for my x5 and 335d. Ive brought some batteries back from the dead with this thing, it's a very nice thing to have.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
04-26-2020, 11:23 AM | #4 | ||
Chief Mambo
24
Rep 46
Quite the dilemma on your X5d! I hope this isn't anything as involved as that, but now you have me wondering if I should go check my X5d drains!!!
2021 X5 M50
2016 M240iRacing |
04-26-2020, 03:18 PM | #5 | |
274
Rep 1,054
Checking your roof drains isn't a bad idea. I'm not sure if anything changed in the roof drain design from my e70 to your f15, but you just shoot compressed air through them. They really shouldn't clog but things can get stuck in there sometimes, especially if you have it open a lot. My x5 wasn't clogged though the hose was pinched between some wiring from whoever initially ran the line for the drain hose. Pretty simple fix though
