04-21-2020, 07:39 AM | #1 |
83
Rep 367
Rough idle, weak acceleration - no CEL
Suddenly today 335I N55 was slow to change gears, and I had to floor it up a hill to get to work. I'm not sure what limp mode is like- it was still willing to rev, just no power.
After parking, it was really noisy, I assume oil cooler running? Hidden menu showed coolant temp (-128c)(culprit??) and oil temp in the high 50s (typically to 90+ by getting to work) Any ideas? I should mention I installed CTS intake on Sunday, car drove normal then and Monday. Only other oddity is I have 20 miles of gas range. I don't see how either of those would make coolant temp read wrong. It's 0c outside. ___________ Update: It was the transmission heat exchanger thermostat. Last edited by tardboi; 05-12-2020 at 10:02 PM.. Reason: resolved |
04-21-2020, 09:01 AM | #2 |
981
Rep 1,560
Pull the codes. They should give you a place to start your search.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
tardboi82.50 |
04-21-2020, 09:43 AM | #4 |
3788
Rep 5,776
You may have what happens to me every few months--there is a fan error that causes the cooling fan to run crazy and puts the car in a half limp mode. Usually it will happen after I have started the car back up. It will drive seemingly normal but will feel sluggish and the fan will be running hard. The easy remedy is shutting the car off and back on. I have pulled codes after this has happened and they are a minor fan error which lead to possibly replacing the fan.
Due to it happening rarely, I have not done anything as of now but it has been happening for more than a year now. These cars have sensitive electronic sensors and what I would call gremlins that will give codes and various limp modes from time to time that are probably not worth fixing . Many of us have had full limp modes and drivetrain malfunctions that happen once or twice a year and never return. How much time and money are you going to spend trying to find something that is probably just a false alarm.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
tardboi82.50 |
04-21-2020, 10:23 AM | #5 | |
10168
Rep 2,671
Pretty sure this is exactly the wrong kind of advice you should give someone in this situation, on a BMW message board. |
tardboi82.50 |
04-21-2020, 11:44 AM | #6 |
83
Rep 367
Thanks for the input everyone. I'll respond when after work.
In the mean time, any recommended app to read codes? I think there's veapeak bt obd in my car. View post on imgur.com View post on imgur.com View post on imgur.com Last edited by tardboi; 04-21-2020 at 12:24 PM.. |
04-21-2020, 01:56 PM | #8 |
417
Rep 919
Did you happen to disconnect something when you installed your intake and forget to plug it back in...like an ambient air temp sensor? Not sure where it is but it's someplace and seems like yours is either broken, disconnected, or has a worn wire.
I'd start there...but also, I'd put gas in the car. I thought I'd read something about the car going into a 'super eco-mode' when you're low on gas...maybe I was drinking at the time.
tardboi82.50 |
04-21-2020, 04:43 PM | #9 | |
3788
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP Last edited by jgoens; 04-21-2020 at 05:23 PM.. |
tardboi82.50 |
04-21-2020, 04:48 PM | #10 |
3788
Rep 5,776
No, this can be completely true and Mechanics and dealers will tell you this as well. Real problems will not get better and will reoccur with regularity and need to be resolved. If you can live with a limp mode once or twice a year and the car runs great then good, or you can spend hours and hours or hundreds of dollars chasing. I was giving my experience regarding a fan fault that happens a couple times a year--his situation may be different.
tardboi82.50 |
04-21-2020, 04:51 PM | #11 |
83
Rep 367
Gentlemen, here are the codes from Bimmerlink -
Central Gateway Module: CD0487 Digital Engine Electronics: 1D2008 Electronic Transmission Management: CF2DE2 Integrated Automatic Heating: 801237, E71408, E7143A Roof Function Centre: 030205 Unlikely related codes: 8011C1, 802A1E, 030205, 8041A8, D90D29 I see nothing related to intake/MAF - so I guess that's good? Looks like... bad sensor? Or water pump or coolant level? |
04-21-2020, 04:59 PM | #12 | ||
10168
Rep 2,671
04-21-2020, 05:28 PM | #13 | |
3788
Rep 5,776
04-21-2020, 05:36 PM | #14 | ||||
83
Rep 367
No, just intake.
Thank you, I will try the Torque app as well to see if it finds anything different from Bimmerlink. Quote:
Shifting was still funny. Still weak, but I didn't push it. It seems to want to hold high gears. |
04-21-2020, 06:30 PM | #15 |
83
Rep 367
Couldnt find anything funny. Unplugged battery and still got codes; started up rough.
If there was a MAF error (i.e. intake) I'd see it, right? Nothing here clues into it being the intake at all AFAICT |
04-21-2020, 10:06 PM | #17 | |
83
Rep 367
They all come up as "consequential faults", or otherwise are not likely related to the issue here (sunroof, seat heater, rear defrost...) with the exception of 1D2008, which says "Check lines and plug connections between the following components: - DME. - Coolant temperature sensor." I think I found both (i'm not entirely sure), and they seemed fine. DME wiring I assume is under this plastic cover: View post on imgur.com Coolant wiring connection is behind the MAF in this picture View post on imgur.com If anyone can advise as to whether or not I am looking at the right area, please do. I checked all over regardless and everything seemed fine, but maybe I missed the fault ones. Thanks again everyone for your input. |
04-22-2020, 07:49 AM | #19 |
83
Rep 367
Wouldn't there be air related errors? I don't see anything broken.
The coolant and oil temps read correct today but still has CEL. Cleared codes and will see what comes back. I couldn't get the torque app to see my OBD adapter, btw EDIT: Cleared codes after getting to work; got home and no new errors. Starting to look like what jgoens said happened to him. If it happens to you again, check to see if your coolant is -128c. Last edited by tardboi; 04-22-2020 at 06:03 PM.. |
04-23-2020, 07:17 PM | #20 |
Car Hypochondriac
335
Rep 901
Drives: 2014 335i M-Sport Estoril Blue
KhristianF30 Sounds exactly like your problem as well.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
tardboi82.50 |
04-23-2020, 08:07 PM | #21 |
83
Rep 367
Good find. Seems like this problem - at least similar to this one, is not that rare.
Now I just wonder if I'm the only one to look in the hidden menu for coolant temp. Only reason I looked is because it made no sense the oil gauge hadn't moved after 10 miles of driving. |
04-23-2020, 08:17 PM | #22 |
Car Hypochondriac
335
Rep 901
Something tells me this is the result of the coolant temp sensor or the wiring/connections to it being faulty, which causes the DME to panic and cut power.
tardboi82.50 |
