04-17-2020, 04:20 PM | #1 |
552
Rep 685
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Exhaust flap code
Anyone else with MPPSK seen this code before?
Had a pretty hard start this morning (it was cold and ethanol starts hard). Exhaust sounded louder than usual and now I keep getting this code. Exhaust flap is definitely stuck open - or maybe it's closed lol. Whichever state bypasses the muffler and puts the MPPSK into straight pipe mode. I've checked all the connections and and wiring and everything looks fine.
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
04-17-2020, 05:58 PM | #2 |
552
Rep 685
Update:
Found a spot where the exhaust flap wire had dropped down a bit and was contacting the exhaust. This had melted the protective covering and exposed the two wires inside. The protective covering on one of these was also melted exposing the wiring inside. I believe from how it was sitting, the wiring had contacted the metal exhaust. Seems like a pretty straightforward two-wire circuit, so I just wrapped the exposed wire with electrical tape and cleared the codes - but no dice. The code reoccurs and the exhaust flap is staying in straightpipe mode.
2020 X3M
04-20-2020, 08:15 AM | #3 |
Cheapskate
4450
Rep 4,993
cut and splice the section that melted.
04-20-2020, 11:47 AM | #5 |
552
Rep 685
I was thinking about that, but also wondered if this short could have blown the fuse. I might try to check that.
Fuse box in my old bimmer was under the glove box. Where is it in the F30? Guess I could Google it too, lol
2020 X3M
kern4174449.50 |
04-22-2020, 03:29 PM | #7 |
1653
Rep 4,882
If not the fuse, then the electronics controlling it (that would be sad). Have you tried pulling the battery cable and clearing the codes? Maybe it latches into some safety mode.
04-22-2020, 03:38 PM | #8 | |
552
Rep 685
Work has been crazy and I've got this cylinder 4 ignition/combustion code that I'm more focused on atm, so it might not get any attention until I figure out what's going on there.
2020 X3M
04-23-2020, 10:43 AM | #11 |
552
Rep 685
Are you saying that your flap control wire was melted by the exhaust also? And that led to the blown fuse?
2020 X3M
