04-15-2020, 01:28 PM | #1 |
Rep 23
USB ports not working at all.
Hey all. I’ve had an id6 retrofitted and it’s been working fine.
In the last few days I’ve had some coding done, change to screen settings and CarPlay activated. Now though, my USB ports are both dead. If I plug in a hard drive, it powers up, so they are clearly powered, but don’t get recognised by the headunit. I’ve tried plugging in different usb sticks, formatted to fat32. These worked after the retrofit but now dont. If I plug in an iPhone, it doesn’t get recognised. Everything else works fine, USB ports just not recognising anything that’s plugged in. Could these have been coded out accidentally? Or any idea what could be wrong here Appreciate any help |
04-15-2020, 09:31 PM | #2 | |
4488
Rep 10,473
Move to the front of the class. |
04-16-2020, 12:27 AM | #3 |
Rep 23
You’re helpful. Maybe instead of being a dick, you could try to help? If you’re capable of that.
A few things; 1. I didn’t make changes, a coder dialled in and made them remotely. 2. The issue of the USB’s not working wasn’t apparent straight away, as I didn’t have use for the USB ports for days. 3. The coder has said that he only made some vo changes first and later some fdl changes to screen size and that he’s confident he didn’t change anything to do with USB. 4. Nothing that I can find online suggests that USB ports can actually be coded out. Last night, I decided to check the FA from a few days after the retrofit against the current one in the car and found some small discrepancies, these; 2PA,302,420,8SM, are no longer listed. I’m going to add them back in today and see if it fixes the issue, but nothing I see online suggests these are related. |
04-16-2020, 01:23 AM | #4 | |
Luxury at the redline :)
9105
Rep 7,563
Incase our resident troll jumps at my throat for not choosing my words correctly; disclaimer, I'm 100% on this but the person in the thread below had a similar issue, so I'm assuming it's related. Good luck. https://www.bimmerfest.com/forums/sh....php?t=1162401 |
04-16-2020, 02:01 AM | #5 | |
Rep 23
Thank you Poochie, that is helpful. I’m going to try and replace the values in the FA today. Not sure i know enough to try coding FDL items, but I’m going to try and find a good guide and see if I can do it. Appreciate the help! |
Poochie9104.50 |
04-16-2020, 10:58 AM | #6 |
Rep 23
So, I've been busy trying to figure this out, set up esys and took a look at the VO coding, made a few changes to see would it help. Didn't do anything. Tried to change the codes in the post that Poochie suggested, couldn't find those but found similar and made changes. They didn't do anything either.
I then injected a CAFD into HU_NBT to see if that could be the issue, didnt do anything. I then coded the HU_NBT ecu back to default to see if there had been some FDL coding gone astray. That didn't fix it either. What I have noticed is that there is no AUX option on the Media Source menu, Don't know if there was before. Seems like there should be though? |
04-19-2020, 01:23 PM | #7 |
1646
Rep 4,877
Not sure your sequence of events, but if you code VO into a module, it will revert everything else you touched back to defaults.
I have an AUX on my media screen, but haven't messed with the USB settings. Helpful FYI, if you start typing the coding string you are looking for at the top of the ISTA screen (in the search box), you can then find/jump to the proper item. |
05-14-2022, 10:47 AM | #8 | |
Rep 79
Have you found a solution? Same problem, but after the iStep upgrade. EDIT Solved my problem; here solution: problem was the USB hub. In general first check if USB ports behind HU works. https://x3.xbimmers.com/forums/showthread.php?t=1925611 Last edited by LikeNo1; 10-17-2022 at 10:54 AM.. |
