E90 330D - Rear Subframe Removal
04-15-2020, 11:17 AM | #1 |
129
Rep 828
Hi All,
So it's time that I replace the rear subframe, a while back in the snow I hit the rear passenger wheel off a kurb and not long ago I reversed at an angle to come off the dropped kurb but instead missed and came off the kurb and into the gutter which destroyed the shock and I think made the rear subframe worse.. Either way I wanted to replace it before as the car wouldn't align even after new Eibach springs, wheel knuckle and all arms replaced so.. Any recommendations or tips? I'm going to drop the rear subframe as a whole with differential and arms still attached. From my understanding all I need to do is remove the exhaust, the brake lines, height sensor, handbrake cable, wheel speed sensor and propshaft from diff? I can't do anything yet as I need to order a 50mm spanner and may need to angle grind it thinner judging from the design of a specific differential spanner. But yeah if anyone has done this before I'd appreciate any tips or suggestions. |
04-15-2020, 04:42 PM | #2 |
3060
Rep 3,912
My e91 330d has a giubo at the diff, rather than the big nut.
You'll also need to faff with heat shields etc. Definitely take the opportunity to install M3 or aftermarket rear subframe bushings while the subframe is out. Diff bushings too....and any other bit that might need or want to be replaced or upgraded. |
04-15-2020, 05:02 PM | #3 | |
129
Rep 828
04-15-2020, 05:16 PM | #4 | |
129
Rep 828
https://youtu.be/WW6dLZC8zIo |
04-16-2020, 12:50 PM | #5 | |
129
Rep 828
https://youtu.be/3lgSUYP7PTA |
04-16-2020, 01:42 PM | #6 |
3060
Rep 3,912
All of the bolts into the donut. I need to do mine too, but putting it off as long as possible. Expensive bit of rubber!
Not sure if you can remove the shaft after the diff is out...I rather suspect you need to unbolt it from the transmission too |
04-16-2020, 02:21 PM | #7 |
129
Rep 828
I mean just to drop the rear subframe, did you just remove the 6 bolts from the donut and lower the subframe or?.. I'm just a little confused whether the differential pulls away from the propshaft while dropping the subframe or whether the propshaft slides towards transmission with the 6 bolts undone . Or whether both sides of the propshaft need removing before the subframe can be dropped?
04-16-2020, 02:42 PM | #8 |
3060
Rep 3,912
If you unbolt the 3 bolts on either side of the donut, it comes apart. So only 3 bolts (from either side) need to be removed from the donut to drop the subframe fully. I'd recommend loosening all 6 (because you need to remove the donut itself) while it's still attached though - they'll be tight!
04-16-2020, 02:55 PM | #9 | |
129
Rep 828
Hopefully things go to plan tomorrow that exhaust was a nightmare, kwik fit rounded off the exhaust bolt a bit (the bolt on the C clamp just after the flex pipe) and, because they tightened it as much as possibly the nut sank into the bracket so a socket wouldn't fit on and a spanner barely did, I had to angle grind the nut off. Then at muffle end the E torx bolts rounded off so rsther than sit there again trying pointless things I had to remove the bumper and then remove the metal bumper.carrier which oddly enough is what holds the rear muffler. It could be coincidence as well, but most subframe I see online for sale including the one I purchased seem to have the brake lines cut.. I have a feeling they can be a pig to get off so I'm not looking forward to that. |
04-16-2020, 03:54 PM | #10 |
3060
Rep 3,912
Haha, I tried to rotate my exhaust a little recently. The but loosened just fine, somehow, even though it was super rusty (thankyou duck oil!), but I couldn't get the damn thing to move! Tightened it back up and I'll just have to live with a crooked tail pipe, until it annoys me enough to fix it (again).
Yep, I had to break then remake the hard lines on the subframe when I did mine. Pain in the ass! |
04-17-2020, 02:00 PM | #11 | |
129
Rep 828
Now, when I went out today I was going to do what you suggested which was removed the other bolts from the transmission side but to do that you would need to remove a sort of brace which also has same transmission mounts so I looked at the center of the Propshaft and noticed that there's a knuckle so I just went ahead and lowered the subframe as is.. I've managed to create a gap between the donut and Differential mounting piece but it just won't pop out, I've knocked a screwdriver and spanner but it don't seem to make much difference so I decided to post here and give it a try tomorrow just on the off chance there is something I'm missing https://youtu.be/gBqlgo3EwjI |
04-17-2020, 02:46 PM | #12 |
3060
Rep 3,912
As far as I know, it's just a close-fitting spigot down the middle. Should just pull out (with a bunch of penetrating lube, swearing, twisting, more swearing, levering, etc)
Edit: I'm talking through a hole in my head/ass...seek advice/check the diagrams on realoem. Or look it up on newtis.info |
04-19-2020, 05:16 PM | #13 | |
129
Rep 828
It still didn't slide out the differential though, there's a piece of metal at the end of the Propshaft that I think is used to center the propshaft into the differential and I had to pry with a spanner to get it to pop out. I had both subframes laid on the floor and the and the wishbone mount was very slightly bent (the arm next to the top control arm) Just waiting on a Propshaft donut to arrive and tomorrow I'm popping to a shop who should hopefully be able to make me another brake line. |
04-24-2020, 09:28 AM | #14 |
129
Rep 828
I couldn't believe the amount of rust under the subframe, and the heat shield nuts and washers crumbled off revealing more deep rust
I haven't done a perfect job but I used a 40 grit flapper disc on an angle grinder and a wire brush and then coated on some Hammeright Underseal with added Waxoyl and it looks a lot better, hopefully it should slow the rust down. Done the same to the differential which looks a lot better Last edited by MrSweet1991; 04-24-2020 at 09:42 AM.. |
04-24-2020, 10:36 AM | #15 |
3060
Rep 3,912
Ugh! I hate rust!! Watch out for that hammerite shit - I've found it washes off after a bit. If you really want to slow down the rust, get some rocol cold galvanising spray (69515)...the price is wild though!
04-24-2020, 11:29 AM | #16 | |
129
Rep 828
Because of where the Hammeright is I'm hoping it won't really get too much abuse as the heat shield, subframe and Differential will cover a lot of it and the arch also has the arch lining. I have to say I was really surprised at how easy it was to coat the Hammeright and it looks a lot better under there now. I put the order in for the Bilstein B4 shocks, top mounts, lower mounts, dust and bump stops yesterday on AutoDoc.. I have a feeling ill end up putting some more Hammeright on out of boredom waiting for AutoDoc |
04-24-2020, 12:31 PM | #17 |
3060
Rep 3,912
Yeah, hammerite stuff is lovely in summer! Awesome gooey slop. Pain in the ass in winter though - it doesn't want to go on. I've put it in a spray bottle, then dunked that in boiling water and sprayed it on, previously
