04-12-2020, 08:39 PM | #1 |
Rep 31
Need help identifying the jack points from this video
I've read a few different threads on this, but was not able to find an answer..
apologies if this answer exists already. It would be easier if I had Esco jack stands but would prefer to use the standard jack stands I have at home already. Anyway, I've been watching the Throtl 335i build and noticed that he jacks up the car on the side, and uses the standard jack stand. Does anyone know where he is putting the stands here? Im pretty new to doing maintenance at home.. your help is appreciated! @2:32 mark.. |
04-12-2020, 11:23 PM | #3 |
Rep 31
04-13-2020, 05:15 AM | #4 |
417
Rep 919
I haven't been under mine to know where exactly he's putting the jackstands, but probably in a spot where a cross brace is mounted...not 'on' the suspension.
You can jack from front or rear center points and put jack stands under front jack points, then lift the rear (again, not exactly sure, but there should be some center rear jacking point in front of the rear differential.) I remember worrying about jacking up my first bmw too, OP. Don't goof around with jacking points...put one in the wrong place, you can injure yourself or your car. If you're still unsure, dress nicely, buy some coffee, and try to bribe a bmw tech at local dealer to tell you. (Watch lots of vids...check the bmw TIS...must be something there.) There is! This is for my car, OP...you can back up from here and find yours, I'm sure. https://www.newtis.info/tisv2/a/en/f...guide/GIcCEaOc
04-13-2020, 06:47 AM | #5 | |
Cheapskate
4450
Rep 4,993
https://f30.bimmerpost.com/forums/sh....php?t=1445680 |
04-13-2020, 10:23 AM | #7 | |
Rep 31
04-13-2020, 10:25 AM | #8 | |
Rep 31
That's very helpful.. thank you so much! |
04-13-2020, 10:27 AM | #9 |
Rep 31
