04-12-2020, 03:05 AM | #1 |
Rep 27
Need help bmw f30 2015!!
Hey,
I bough a 2015 BMW F30 328i Luxury Line from Copart on June and sent it to a guy and fixed it for me. it had no electrical problems and there was no lights in the dash. when I came to pick it up, the car's lights wasn't working. the problem was the fuse box so I replaced it with a used OEM fuse box. but my OBD isn't connecting to my phone and the passenger door doesn't lock electronically. the car used to work perfect before the shop fixed it for me. some people say I have bad module and I don't know what to do. Please Help |
04-12-2020, 05:44 AM | #3 | |
poopycat
266
Rep 791
There's a lot missing here, but probably nothing we can help with until he can fix the can bus (code pulling) problems. That might inherently be the problem. I'd bet a buck that this is a water soaked car from the south, but what do I know about this? |
04-12-2020, 05:26 PM | #4 |
Rep 27
04-12-2020, 05:29 PM | #5 | |
Rep 27
04-12-2020, 05:39 PM | #6 |
1646
Rep 4,877
My advice is get it scanned with a real tool (like ISTA that BMW uses). That would get you info on all the modules which should show you one that is throwing errors or is non-responsive.
Search for ISTA (there is tons of links in the coding forum). You can do this for free / almost free. |
Abdulsamad1.00 |
04-13-2020, 02:34 PM | #7 |
154
Rep 387
I'm wondering if the rear electronics module was damaged in the accident, and if it was replaced, I'm wondering if they used an aftermarket unit. I would guess that this is probably the culprit, but the best way to know for sure is with a scanner like the Schwaben/Foxwell code scanner or something similar that would let you test the functions of that module, including activating the rear lights.
04-13-2020, 02:37 PM | #8 | |
Rep 27
