04-12-2020, 02:14 AM | #1 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Newer iDrive controller (ZBE4) retrofit not working
My car originally came with NBT and a touch iDrive controller, recently I did a full NBT EVO retrofit with a working ATM along with a 10.25" touch screen, everything works great. My understanding is that the iDrive controller in my car is currently on the CAN2 bus but when I plug in the newer controller it does not work.
When I load e-sys it shows the newer controller (ZBE4) and actually reflects the CAFD level, but when I try to read coding data I get an error message. With the original controller plugged in it shows ZBE3 as it should. I loaded ISTA and I just get code S0393 "No communication possible with: Controller" Am I wrong in my assumption that my car has the controller on the CAN2 network already? I checked the wiring diagrams and the color coding indicates it is indeed CAN2. The colors of the wires that plug into my controller are the colors in the diagram. Is there something else I need to do? Or do I need to tap into CAN2? |
04-12-2020, 07:40 AM | #2 |
588
Rep 2,302
I think the connection is right, because the ZBE4 is visible and the wiring colors are the same.
I only don't understand why there is a CAFD already. But did you already try to code the ZBE4? |
04-12-2020, 01:51 PM | #3 |
E36fiend
285
Rep 637
I did try to code it, got the same error. I also tried using 'Detect cafd for swe' which lets me pick the cafd version but I got the same error as when I tried to read coding data. Is it a faulty unit?
04-12-2020, 02:06 PM | #4 |
83
Rep 440
It depends what donor car you got the retrofit from. If it's from the anything but the F30 then it won't work as the new G series use a different method of communicating. I had the same issue when I retrofitted NBT evo into my LCI f30. My donor car was a G30 and everything worked but the controller. I had to buy an updated controller from an f30 and it worked without a problem.
04-13-2020, 01:27 AM | #5 | |
E36fiend
285
Rep 637
04-13-2020, 08:11 PM | #7 |
E36fiend
285
Rep 637
I looked at the G30 wiring diagrams in newtis and the controller is on the CAN4 bus going to the BDC as there is no FEM in later models, also it appears there is no touch controller. It's been debated whether CAN4 can be referred to as a renamed CAN2 depending on the architecture but I dunno, could be there's some different electronics inside the Gxx series controller.
08-24-2021, 02:02 PM | #8 | |
Rep 21
I have exactly same issue... If you did fix it can you please share solution... Thank you |
08-24-2021, 04:04 PM | #9 |
E36fiend
285
Rep 637
08-24-2021, 04:33 PM | #10 |
Rep 3
08-25-2021, 07:05 AM | #11 |
25
Rep 31
is possible to make Gxx controller work in Fxx cars but will require an emulator/can filter.
I have in my F36 the ceramic controller from G11.
Current cars: 2016 F13 640XD ; 2017 F36 420XD
Past cars: 2010 E93 320i ; 2008 E60 530XD ; 2006 E90 320D |
01-02-2022, 09:00 AM | #13 |
Rep 2
Hello. Please advise the coding, error -CON 026708-touchpad. Installed the controller iDrive from NBT evo swears that there is no touchpad module, as I understand it. Saw it somewhere, can not find it. car BMW F30 2018.
09-09-2022, 12:24 AM | #14 |
Rep 6
I installed an iDrive from a 2017 F30 to a 2015 car. It shows up as ZBE4 and I’m seeing this expect problem when try coding it. ISTA shows these two errors:
026708 CON: No current coding data stored 02670B CON: Control unit is not encoded for the vehicle At the same time the new iDrive works (although with the old pre-LCI button mapping). Anyone has figured this out? |
09-09-2022, 07:49 AM | #15 | |
Coding ECU's remotely
445
Rep 1,176
11-08-2022, 07:46 AM | #16 |
Rep 62
I have same errors after retrofitting NBT Evo ID6 in my car, F20 PreLci 2015, controller works perfecltz, touch works, new key mapping works (not inverted). I need only to solve these errors.
I get ZBE4 error when trying to read CAFD mapping |
05-07-2023, 02:57 PM | #18 |
Rep 25
If anyone in this post has figured out how to make the ZBE4 work with an F-Series with EVO, please provide instructions and/or the directions on what needs to be done (coding, flashing, etc.) to have it work properly. I've seen posts where folks comment that they can do it, or it's possible, however, I've never actually seen anything that describes what needs to be done.
This would make a lot of F-series folks who are doing the EVO retrofit very, very, happy. Thanks!!!! |
05-07-2023, 05:35 PM | #19 |
288
Rep 539
I didn’t need to do anything on my car. I have a 2015 F30 with retrofitted Evo. Was using the old ZBE3 controller for a while but a few days ago I bought a ZBE4 controller with a 2020 production date. It worked right away without having to do anything.
Just coded Evo to use the new button layout and I injected a CAFD into ZBE4 then coded it to stop ISTA complaining but it hasn’t changed anything in terms of functionality. Clearly there are some controllers that are KCAN4 that don’t work right away and do need something else to be done. Does anyone know how to determine what these controllers are marked with? I wasn’t sure if my 2020 controller was going to work but luckily it did. |
05-17-2023, 03:43 PM | #20 |
Rep 49
hi, I have luck problems on my f34 gt, have changed my nbt to nbt hu and my touch control is showing error on bimmerlink also has the touch module, does anyone know how to fix this
