04-10-2020, 03:10 PM | #1 |
475
Rep 1,325
Best coating to protect new wheels?
Got a refurbished set of 403m's without tyres, what's the best thing to put on them to protect them, is there any kind of coating worth applying prior to fitting tyres?
04-10-2020, 03:25 PM | #2 |
372
Rep 1,425
I'm not an expert on this topic. However, I did have my wheels ceramic coated. One set has Opticoat Pro+, and the other Ceramic Pro (marine application). I doubt you're going to find anything to truly "protect them," but ceramic coating will make it easier to clean.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
04-10-2020, 03:25 PM | #3 |
4516
Rep 8,942
You can ceramic coat or wax, multiple products choices for either.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
04-10-2020, 04:09 PM | #5 |
259
Rep 517
Get a brush for a drill and just clean them as needed. I let mine get a bit gross over the winter because it's too damn cold to be scrubbing rims, so I bought a brush and it took off all the gold/brown brake dust that had built up over the winter. Just be careful to not hit ABS brake sensors
04-10-2020, 04:24 PM | #6 |
1599
Rep 3,748
The question is how often you clean your car?
If you don't clean often, say twice a month then go get it ceramic coated, it will make it easy to clean your wheels OR Clean car twice a month, clean after wash then spray with hybrid ceramic wax... wipe and good to go. |
04-10-2020, 04:26 PM | #7 |
8245
Rep 16,088
I treat mine with Wipe New for wheels, it reduces brake dust build up considerably, and makes keeping them clean much easier.
https://www.amazon.com/Wipe-New-WW6P.../dp/B00MBPLPII When they do need cleaning nothing beats Brown Royal. https://www.flashautodetailproducts....-tire-cleaner/ It's great for cleaning anything that gets oil and grease on it, and you can dilute it with water up to 5:1, so it's not expensive. |
imperfectluck426.50 |
04-10-2020, 04:32 PM | #8 | |
1599
Rep 3,748
04-10-2020, 04:36 PM | #10 |
278
Rep 280
As mentioned above, OptiCoat Pro is a very good chemical resistant coating but it is only offered through installers meaning you would have to pay someone a pretty penny to get it done.
I did my wheels in CarPro Dlux which is specifically designed as a wheel coating but I am still testing the longevity. Only had it on the wheels for 6mo before storing the vehicle for winter Gtechniq C5 is another wheel specific coating. As with any ceramic, it makes them much easier to rinse off and wash. The question of it being worth it really comes down to you, personally I don't find it to be as awesome as ceramic coating your paint but that's not to say I won't go all-out when it comes to detailing as it's a large passion of mine. If you are going to go the DIY route make sure you follow the proper prep procedures just as you would with paint by giving them a good wash with an iron/fallout remover, tar removal (if necessary) and clay bar prior to coating them. |
