04-10-2020, 11:37 AM | #1 |
16
Rep 98
KW V1 coilovers on F30?
Who here is running KW V1s on their f30?
how are the preset dampening settings? are you happy with your purchase? Thinking about getting them for my 335i x drive. I don't track my car as she is my daily but i still drive pretty aggressively at times so i definitely don't want to lose all stiffness. 'm curious to see how the feel of V1s are. Thanks. |
04-10-2020, 04:40 PM | #4 |
362
Rep 90
Drives: 2016 F31 Msport/Track handling
I love mine, I'd say I actually like the ride better than stock. I had the track handling package with the adaptive suspension too. But honestly you should see if you can get a ride in a car equipped with it, try and keep same tire and wheel size too as that makes a huge difference, any misgivings I may have about the ride with V1's (mostly crashing over larger road imperfections) go away when I switch from my 20" BBS back to the stock 18" THP wheels/tires. The car is always completely stable even on rough uneven pavement, something I noticed wasn't always the case, even with the stock adaptive suspension.
I went with KW because I my past experience with them on other vehicles gave me no question on the comprise between ride and ride height adjustablity I was getting my self into.
2018 S213 AMG E63S Estate: Diamond White - Money-pit/Garage Queen
2004 CL9 Acura TSX 6-speed: Satin Silver - Peak JDM 2018 BEV2 Chevy Bolt: Nightfall Gray - Daily driver |
CT716.00 |
04-10-2020, 05:43 PM | #5 |
251
Rep 426
thatBimmerBloke
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
04-10-2020, 07:03 PM | #7 |
873
Rep 1,079
Is it stiffer? I can't say for sure. Feels close to stock suspension. The springs being progressive might be making me feel that way. Only improvement in handling and body roll is possibly from lowering of the center of gravity. There's no loss in comfort and it absorbs the road irregularities/bumps better than stock suspension. I was expecting it to be stiffer. I might have liked the B14 better, the springs are linear and stiffer. However, you get more ride height adjustibility with KW, you can go low without pushing the coilovers to the limit. With the height that I'm on right now the B14 would've been at the lowest setting and it does not do well when pushed to the limit.
I asked a lot of members before getting KW V1 and nobody has ever had any issues, some even had them on for 80k miles without any issues, build quality and reliability is top notch. Good luck. |
CT716.00 nitro_boss15.00 |
04-11-2020, 10:59 AM | #8 | |
282
Rep 775
How low are you now out of curiosity? like how many inches/millimeters
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
CT716.00 |
04-11-2020, 02:28 PM | #9 |
873
Rep 1,079
My front wheel gap was 2 1/8" and rear was 1 5/8", the rear was sagging, not sure why, I've about 48k miles on my car. I asked a member with a fairly new 440 xDrive and he had 2 1/8" gap all round, front as well as rear. Right now my front gap is 5/8" and rear is 3/4", I wanted a little bit of rake. So the lowering is about 35mm rear and 40mm in the front when compared to a newer 4 series xDrive. It was about 5-10mm lower for a few days, looked much better but I wanted some clearance for my driveway which has a huge slope. I'll raise it about 10-15mm for winter. I'd definitely go 5-10mm lower than where I'm now if the driveway wasn't an issue. I think KW can lower up to 60mm. This is when it was lowered about 40-45mm, again, no loss in comfort even at that height.
alohasurftoad3081.50 joeyb26281.50 |
04-20-2020, 05:20 PM | #11 |
17
Rep 78
04-20-2020, 05:48 PM | #12 |
373
Rep 937
Very happy, I got rid of my run flats, then went with KWV1s. Sure some bouncy spots are more rough, but it makes up for it with better driving in the corners, braking, accelerating!
Hi
