04-04-2020, 05:33 AM | #1 |
417
Rep 919
Used wrong torque on plugs. How bad?
Edit--nevermind--I misread torque setting--I did use the right torque for my plugs. I was going off socket size, not thread size. Thank you all for your help below!
I just learned that I used 23Nm (18 ft/lb) instead of 30Nm on my plugs. Both have tolerance of +/- 3 Nm. First time I used a torque wrench since I'm worried about breaking my b58 and I use the wrong torque. The car is together and runs great. But, I'm short some Nm on the plugs. So, I'm assuming I'm a full 23Nm tight and 27 Nm would be fine. So literally I'm 4 Nm short of being tight enough. I'm also over 10% light. Serious consequences beyond hearing some tapping in some thousands of miles and needing to re-tighten them then?
04-04-2020, 06:30 AM | #2 |
212
Rep 231
You shouldn't see any consequences. I'd go back and try to give that extra bit. In your case though it's better that you were a little under torqued than over. Cracking a plug is way worse.
2015 F30 335i EBII MSport
M Perf Exhaust | M Perf Brakes | M Perf LSD | CTS CP | CTS Catless DP | FMIC | BM3 Stage 2 93oct | 20" 405m | 10/15mm Spacers | KW V3’s | Vorshlag Camber Plates |
04-04-2020, 06:35 AM | #3 | |
417
Rep 919
I appreciate the confirmation. I figure I have about 30 degrees from contact...maybe it wanted another 5-10 degrees. I'm not tracking or dragging my car, so for now I might leave them be. They're 'just' snug. Fingers crossed!
04-04-2020, 06:40 AM | #4 |
212
Rep 231
I don't think I have ever "properly" torqued my plugs down with an actual torque wrench. You wouldn't see a difference if you were tracking/dragging the car over everyday driving. The only possible issue would be the plug slowly backing out due to the vibration. But at the 24nm you did, you should be fine.
04-04-2020, 07:08 AM | #5 | |
417
Rep 919
I got the torque wrenches knowing I'd need them to bolt things into magnesium at some point...maybe. Anyway, I need to take more breaks and more ale when DIYing.
04-04-2020, 02:39 PM | #6 |
1646
Rep 4,877
I wouldn't worry about it. The concern would be going the other way since you can strip threads.
I'm pretty sure when I changed my last set of plugs, it was "ok, snug, and a bit more" with the ratchet. |
04-04-2020, 06:13 PM | #7 | |
809
Rep 1,597
04-04-2020, 06:39 PM | #8 |
417
Rep 919
According to the TIS, 23Nm is for 12mm plugs. Mine are 14 and call for 30 Nm...+/- 3 Nm. So I'm 4 Nm or 2.8 ft/lbs light...and if yours are 14 mm too, then I guess I'd ask how long yours have been in so I can stop thinking about going in for under 3 ft/lbs of extra tightness.
04-04-2020, 07:07 PM | #9 | |
809
Rep 1,597
04-04-2020, 08:47 PM | #10 | |
417
Rep 919
...My boxes say go to the stop, then add 1/16 -1/12 turn...at least I think the diagram means tighten to between 1/16 and then add another 1/12. Not exactly clear, but I'm probably somewhere in that neighborhood...and I feel better, but man, either way, these plugs are in lightly. My old ones started at 2/3rds turn, then another 1/4...a bit more torque. I'm getting old...I didn't see the label on the box...was only thinking of the TIS...and I got that wrong, as the 14 mm is my socket size, not the thread. So...I torqued them okay. Thank you, bmwiluvu. I owe you a beer in the 'clean' time that I hope is ahead soon!
