PLS HELP, 335i no ignition won't start
04-01-2020, 11:41 PM | #1 |
33
Rep 120
Drives: Bmw X5M, M6, X5 5.0, 335i
!!!SOLVED!!!
Hi first of all I have read every possible thread and watched all YT videos nothing helped me. 335i, 2007 (10/10/2006), 125k stock The car was in running condition the battery seemed weak recently. One day the car didn't start so I jumped start it through the post in engine bay. Next day I didn't try to start the car I just called tow truck to tow it to the shop for scheduled turbos installation. (note that I called the tow truck not due to battery problem but bcs the turbos where already that bad that the car was not drivable) Next day I got a phone call from the mechanic to come that they can't start the car nor put it in neutral etc. (they didn't start to work on the car yet) I got there tried everything with no success so I ended up towing the car back home to have more time for my investigation. Here are the symptoms Car lock and unlock with the remote, lights, radio, windows, wipers, el. seats everything works just fine when insert key in slot everything seems fine dash shows key symbol all good. when I press the start button doesn't matter if with foot on the brake or not only airbag light light up no click from starter no other lights on dash which normally shows up it just doesn't turn on the ignition at all. Don't have second key to try but don't think could be a key. Everything what I have tried. -New battery - battery ended up be bad so i bought new one (I'm suspecting that whole the thing has something together with the dead battery) -Checked: -voltage everywhere all positive cables from battery all cables in engine bay all OK -engine ground OK -voltage at starter OK -starter OK working good -all fuses and relays -disconnected IBS no change (currently not getting IBS fault codes but was getting prior this don't know if it was due to weak battery or if IBS is faulty but what I have read disconnected IBS should let the car start -reset ELV counter no change I'm pretty sure that I have tried more things I just can't remember at the moment. Faulty codes using INSTA: S0063 No communication possible with Amplifier S0085 No communication possible with DSC S0195 No communication possible with Telephone control unit 005088 EGS sensor, gearbox selector switch 00A3B2 Message error (terminal status, 0x130) receiver instrument panel, transmitter CAS 00A554 Instrument cluster: no message (telephone) 00A731 JBE: Supply, terminal 30g_f 00ABEA Radio connection to aerial diversity: Line disconection 2 errors in CAS 9A1A ELV_Kommunikation_Inhalt_Info_Fehler 9A3A Weiderholstrategie ELV Entriegeln fehlgeschlagen Tow it to the dealer not considering as an option as I'm not willing to sponsor their experiments. Any help suggestions opinion appreciated !!! SOLVED !!! Steering column lock was the problem. Ordered ELV emulator from eBay, connected and it fired right up. Last edited by Pruzina; 04-23-2020 at 10:40 PM.. |
04-02-2020, 12:24 AM | #2 |
296
Rep 2,015
Sounds like the starter.
When they go, they just go, with very little warning. Have you tried lightly tapping the starter and then immediately try to start the car? Look at your intake Manifold. second last opening. If you look straight down, you should be able to see the starter, I took a 6 inch and 3 inch socket extensions and placed it on the starter, then hit it very lightly with a hammer. When you drive a nail in a wood, you start with a light tap on the nail, that much tapping. also, make sure you jump start it, cause you make have a low battery. just curious, how do you know the starter is good and working? |
04-02-2020, 12:35 AM | #3 |
33
Rep 120
04-02-2020, 12:42 AM | #4 |
700
Rep 1,227
yeah its probably still the starter... in these cars they have good ways to fail internally pretty catastrophically. Plus its a known issue on this entire platform.
04-02-2020, 12:42 AM | #5 | |
2697
Rep 4,031
It will show you "Terminal" Activation: 1) Terminal 15 should be active when Ignition is ON; 2) Terminal 50 should be active during starter cranking; 3) INPA also has ELV diagnostics, but my late 2007 328xi does NOT have ELV, so I can't offer any advice on how to use that. It sounds like either the Transmission/Gear Selector is NOT sending P/N signal, OR the ELV is preventing CAS from sending the 12V+ Activation signal to the Starter. INPA should quickly show you what Inputs are being received by CAS and confirm that Terminal 50 is NOT being activated (Start signal to Starter Solenoid from CAS). QUESTIONS: 1) Does Instrument Panel light up in normal fashion when you put remote in Insert Compartment & Press START, WITHOUT pressing Brake Pedal (Ignition ON)? Your description above suggests that it does NOT? 2) Can you move shift lever from Park to Neutral with foot on Brake & Ignition ON? 3) Does Gear Selected Display on EITHER the Instrument Cluster, OR the Gear Display Light to left of Selector Lever? Please let us know what you find, George |
04-02-2020, 12:51 AM | #6 |
33
Rep 120
1) no it does no that's why I'm thinking that it should not be starter. When starter is busted it usually at least light up the cluster and then fail to start.
2) no I Can't as the ignition is not activated and shift lever is blocked bcs of that 3) nothing on the instrument cluster, it is showing P at the shift lever watch the video. |
04-02-2020, 12:53 AM | #7 |
33
Rep 120
Okay but it turned over the engine when I applied 12v to the starter. and also I think the instrument cluster would at least light up. At least that is what I saw in every single video on Youtube showing failed starter
04-02-2020, 02:02 AM | #9 |
33
Rep 120
just bought it couple days back to solve this problem. I'm still learning how to use it but I'll definitely try your suggestion tomorrow.
But again if there would be issue with brake switch or shift lever switch or anything like that yes CAS would not let you start the car but you would be still able to light up dash board "accessories mode" Last edited by Pruzina; 04-02-2020 at 02:29 AM.. |
04-02-2020, 12:37 PM | #10 |
2697
Rep 4,031
CAS/ELV Diagnosis with INPA
Attached are Seven Screens from INPA which can be used to diagnose "NO Crank issues.
ALL 7 screens are after connecting to CAS & selecting F5, Status in CAS Main Menu. KL = Terminal: 1) F5 > F1 > F2 Status Terminal Control, showing Brake, Gear Position (P/N) & ELV Unlocked (Brake pressed) 2) F5 > F2 > F1 Terminals, NO key yet inserted, just open door & connect INPA; KL30G Active 3) F5 > F2 > F1 Terminals, Key inserted; KLR - Radio now active 4) F5 > F2 > F1 Terminals, Key, Ignition (START/NO Brake); KL15 now active 5) F5 > F2 > F1 Terminals, Key, Ignition, Brake pressed & START; KL50 briefly active during Starter Crank 6) F5 > F5 > F1 ELV Identification (NO ELV on US Vehicles built after 3/1/2007, so "00" 7) F5 > F5 > F2 ELV Values; NO ELV on mine so "Result NOT Available" = "Ergebnis nicht verfügbar" George |
04-02-2020, 07:27 PM | #12 |
33
Rep 120
Here is what I've got. I'm not expert but something is telling me that the damn ELV is the culprit but maybe I'm wrong.
and I should add that the car is 2007 but production date 10.10.2006 so possiblly has steering lock. But the steering is not locked neither with or without key presented. |
04-02-2020, 11:11 PM | #14 | |
2697
Rep 4,031
What appears pertinent to me is this part of the Bentley description: So it appears that KL15 (Ignition) does NOT activate when you press START unless the ELV UNLOCKED when you put Remote Key in Insert Compartment (and heard a "clunk").Check that the key holder locks the key in position, and that the steering lock unlocks (an audible "clunk" can be heard when the key NONE of your "Status CAS Diagnose Terminals/Ignition" screens show any activation of KL15/Ignition, and your Instrument Cluster does NOT light. NONE of those screens show ANY voltage for "Voltage KL30_ELV", AND your FIRST screen (digital circles showing Terminal Status) does NOT have the ELV Release circle filled. I'm confused by ONE CAS Fehlerspeicher (Fault Memory) screen showing "No Error Found", and then 12 seconds later, you have TWO Fault Codes. Had you cleared those two codes and they came back after 3 attempts to unlock? The two Fault Codes are BOTH currently present at 3:37:52 PM today, and NEITHER would cause a warning light. 9A1A, "ELV Kommunikation Inhalt Info Fehler" = ELV communication content info error, No Signal Or Value (kein Signal oder Wert). That means the CAS Module is NOT receiving the necessary signal from the ELV, so is NOT activating Terminal 15 (Ignition). That is essentially an "Immobilizer Function". Your other CAS Fault Code, 9A3A, "Weiderholstrategie ELV Entriegeln fehlgeschlagen" = Repeat strategy ELV unlocking failed. So I would check the connectors & wiring between ELV & CAS, and search for threads dealing with ELV malfunction. Your last screen, Status ELV Values (Werte) shows an error message, "Job Not Found". Try selecting "Yes" to Continue Script Processing, and see if any helpful data/values appear. ANYONE with a model built in 2006 which has ELV who can help here? If you furnish the last 7 characters of your VIN, we can try to find a part# for the ELV. George |
04-02-2020, 11:47 PM | #15 | |||||
33
Rep 120
oh Man you told me that many informations that I don't even know where to start
First of all wiring diagrams are in my eyes just mess of lines and numbers have no idea how to read in them. I'm not sure right now if it never lock but I think it doesn't. But definitely with the key in I can turn the steering wheel however I want so the lock is not in place. And I do some noise from steering column when I insert the key and while after I remove the key. But the lock doesn't engage. Weird. But I'm getting yellow icon as shown bellow but I was not really putting attention too it as I was getting it before and I thought that it means that the steering wheel is unlocked. I was trying to find meaning of this icon and weird enough there is nothing about that in Bentley manual or online. NEVER got red icon never padlock. But symptoms are exactly the same as people with red padlock icon. That is why I was trying to reset ELV counter. It really looks there is going to be SOME issue connected to ELV. Quote:
honestly I don't know the difference. But if I try to clear the memory the codes are still there Quote:
VIN PA87677 Last edited by Pruzina; 04-03-2020 at 12:05 AM.. |
04-23-2020, 10:45 PM | #16 |
33
Rep 120
!!! SOLVED !!!
!!! SOLVED !!!
Steering column lock was the problem. Ordered ELV emulator from eBay, connected and it fired right up. Thanks to all of you who tried to help and specially big thanks to gbalthrop , thanks to you I was investigating right thing. |
essjon1136.50 |
06-14-2023, 01:13 AM | #17 | |
Rep 14
06-14-2023, 02:48 PM | #18 |
Robot
1685
Rep 2,191
I had a similar issue with the ELV and used this one:
https://www.lacartech.com/products/e...277206f4&_ss=r I have zero affiliation with this company but chose them because they offered local pickup. They are a legit shop and very knowledgeable, answered a few questions I had. I had this emulator on my 325i for a long time without issue. I figured I'd try the emulator route and if that stopped working I'd remove the original steering lock and clean it up so it works but that hasn't happened yet. 5 years on the emulator and it's still working well. Just make sure if you install this you can get the original steering lock to unlock, then disconnect (unplug) it while it's unlocked. |
