Power Steering interval
03-31-2020, 06:37 PM | #1 |
367
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
last time I did power steering was April 2018 and its about to be two years. Do you guys replace it every two years accurately or just do it whenever or every 3 years. The reservoir looks half full kinda or 75% and one of the techs say when your autox or tracking the fluid boils and can come out of the reservoir. Is thatt trueee?
03-31-2020, 08:24 PM | #2 |
Is it the shoes!?
3884
Rep 5,112
You're more likely to do harm than good by changing it out every two years by means of introducing dirt or grit. You also don't need to change it all the time. I tend to do it every 100,000 miles. When I did it, it looked fine.
The power steering fluid has a weep hole built into it. It will very slowly leak over time, but it's not an appreciable amount. This is why when you clean the reservoir it always seems to get a little dirty again later. |
04-01-2020, 02:11 PM | #3 |
General
17317
Rep 18,740
I've changed mine every 150,000 miles. I've done it twice now. If the reservoir is oily, just get a new o-ring for the cap.
NBA is correct, the more you change it, the more chance to get dirt into the system. |
04-02-2020, 02:34 AM | #4 |
367
Rep 780
Oh wow. Im at 137,000 miles right now and i changed it two years ago. So its not even good to open the cap up? Dirt gets in? The e90 steering system can allow such long interval?
04-02-2020, 09:34 AM | #5 |
1903
Rep 6,968
When I had my 335 still in warranty years ago, the service mgr always recommend the power steering fluid be changed every 50,000 miles
04-02-2020, 09:38 AM | #6 |
367
Rep 780
Thats sweet so they do it once or twice before they let you go without warranty. Ive had like 5 valve covers changed because of warranty LOL
04-02-2020, 11:35 AM | #7 | |
1903
Rep 6,968
I've always thought that once you get to 100,000 miles to change out all the fluids and then change them every 50,000 except the brake fluid. Reason being the parts these fluids protect aren't new anymore. They won't hold up to a fluid that's 75,000 plus miles old like they used to when they were new. |
04-02-2020, 11:37 AM | #8 | |
1903
Rep 6,968
I have 173,000 miles on my 07' 335, and it has the Original Valve cover from day one. No leaks either |
04-02-2020, 03:42 PM | #9 |
367
Rep 780
LOL No way one valve cover? sorry mines was 5 valve cover gaskets and 2 valve cover replacements. How about you? your gaskets?
04-02-2020, 05:17 PM | #10 | |
1903
Rep 6,968
I didn't do number 1. I finally got smart on number 3 and sandwiched the gasket in between 2 beads of Ultra Black. No leaks I've run 19.6 psi w/ stock turbos. My turbos are original too. |
04-02-2020, 07:00 PM | #11 | |
367
Rep 780
