Is there a PDC Switch for 2013 e93
03-31-2020, 05:16 PM | #1 |
Rep 23
i'm trying to retrofit PDC sensors (front and back) on my 2013 328i convertible. i have sensors, module, wiring. but i'm missing the switch.
do i need a switch, and if i so, i can't find it on real oem. anyone know the part number for the switch? Thank you DoN |
04-01-2020, 10:45 AM | #2 |
118
Rep 342
The switch is included in the center console switches with options like heated seats, descent control, rear sunshade...
The easiest thing to do is to search ebay for a switch that has your options plus PDC. You can use PDC without switch, but it will only turn on when you are in reverse, the purpose of the PDC switch is to turn on the system when you are not in reverse. The part number for a switch with only PDC is 61316962590. If you can not find a switch with the combination of options you need, you can buy new kit that allow you to make the options you need - but it will be much more expensive going that route.
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
