TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Is n54 oil pan gasket DIY different from 328/n52?
      03-31-2020, 03:09 PM   #1
Fusion1250
Fusion1250's Avatar
Drives: BMW 335is
In the diy forum there I couldn't find an oil pan gasket DIY for an n54. Does this mean it is universal to the e9x platform?
Jack Pooley
      03-31-2020, 03:27 PM   #2
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Slightly yes
      03-31-2020, 06:14 PM   #3
mainbearing
1082
Drives: BMW 328i
      03-31-2020, 06:16 PM   #4
mainbearing
1082
Drives: BMW 328i
Either engine, I wonder if the control arms need to be disconnected. Or if this DIY (in genera) will work on the N54:
https://www.e90post.com/forums/showthread.php?t=1180020
      04-01-2020, 07:57 AM   #5
NGEE
Fuck it dude, let's go bowling.
NGEE's Avatar
888
Drives: 1M
I don't know whether you can DIY the oil pan on either engine without disconnecting the control arms, but I would recommend using the opportunity to replace the engine mounts particularly for N54. For that, in my experience I'm not sure how you'd do it without completely dropping the sub-frame.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
      04-01-2020, 01:55 PM   #6
fastboatster
382
Drives: 2009 bmw 328i
From what I could gather, newtis suggest that the factory procedure is to remove the strut nuts and lower the entire subframe with everything bolted to it a few inches. This presumably gives enough clearance to take the pan out. Actually, this may not even involve taking the strut nuts off and they do it as in the diy posted above
      04-01-2020, 04:15 PM   #7
pelon222
13
Drives: E90 328i
If I remember correctly, I only took the strut nuts off on one side only, I didn't have to remove control arms. Swaybar links yes.
