What more to do with the subframe lowered?
03-31-2020, 02:58 PM | #1 |
118
Rep 342
I've had a leaking oil pan gasket for quite a while, this seems like the perfect time to take care of it. I have a 2007 E93 328i with 105k miles, it's in the garage up on jack stands with the subframe lowered.
I'm replacing the oil pan gasket and the transmission filter. Does anyone have any recommendations on what else to do while I have the subframe lowered?
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
03-31-2020, 03:06 PM | #2 |
641
Rep 1,245
engine mounts
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
03-31-2020, 03:12 PM | #4 |
2188
Rep 5,002
M3 swaybar.
Replace thrust bushing with something, M3 bushing, monoball, or a small bucket of water. Anything better than stock. Look for water pump trouble codes. Check all ball joints for wear. |
03-31-2020, 03:26 PM | #5 |
1903
Rep 6,968
Pre-cat O2 sensors
Megatronic sleeve Coolant flush |
03-31-2020, 06:07 PM | #6 |
1082
Rep 1,676
I'll be doing mine, but +1 on motor mounts, oil level sensor o-ring as shown here:
https://www.1addicts.com/forums/show...07&postcount=6 Plus the junk plastic PCV y-pipe if your engine has that. Water pump and thermostat if not already replaced. BTW, did you remove the control arms? Or just loosen the 6 subframe bolts and let the thing hang by itself? |
04-02-2020, 03:09 PM | #7 | |
118
Rep 342
