F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Alpina Flash for F30 F3x 335XD
Extreme Powerhouse
      03-30-2020, 08:14 AM   #1
xpro
171
Drives: 335XD
Hi,
Im going to start this thread with hope that someone will be able to chime and help to get Alpina flash going..
I have tried all steps for Alpina EGS flash on my 2016 335D with no success.
Istep Shipment F20-16-11-502
Istep Target F20-20-03-524
Changed TypeSchlussel to 3E51, and write VO 920 & 9XA.
Read SVT, Calculate KIS/SVT Target, Complete Flash, & TAL calculation
All my ECU entries are blue color and no requering any flash.
The Flash only gives HWdeinstall, so something is wrong.
Is it the PSZData that its too fresh for Alpina or can someone please give a better method.
The link I used for reference is below:
https://f30.bimmerpost.com/forums/sh....php?t=1628967
Also see the screenshot of where my problem is:
Many Thanks
      03-30-2020, 09:07 AM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
You have Full psdzdata installed?
The Link is great, i often recommend these instructions.
Your psdzdata are OK, but you need the Full.
If the calculation is right you should see the swfl_0000210b at the EGS ecu.
Then you can Start the flash.
      03-30-2020, 12:53 PM   #3
xpro
171
Drives: 335XD
Hi,
Yes using full pszdata.
I just flashed my NBT, FEM & ZGW using the same data, and then straight after editing FA and put Alpina codes and all I get is blue icons.
Even tried esys 3.27 but that wont even load the new pszdata. Probably too new.
      03-30-2020, 03:57 PM   #4
atzebmw
Germany
588
Hmmmm...
What happens when you make the calculation with the original VO?
Are then any updates found?
      03-30-2020, 04:01 PM   #5
xpro
171
Drives: 335XD
Hmmmm...
Yes they are. Thats the strange thing.
As soonest I add 3E51 and Alpina vo, it gives me only HWdeinstall option..
I will try again tomorrow first with VO codes only 920 & 9XA and then with 3E51 and see what happens.
Im starting to think it might the PSZData being too new, but Im not sure.
And I dont have any older pszdatas to try
      03-30-2020, 04:25 PM   #6
atzebmw
Germany
588
No, i don't think the psdzdata are too new.
I just made some tests with the newest psdzdata and my Alpina VO and it works without problems.
If you want, you can also send me your VO and SVT_IST and I'll test it.
      03-30-2020, 06:02 PM   #7
xpro
171
Drives: 335XD
Great, I will do that. Thanks!
      03-31-2020, 11:23 AM   #8
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
To bad it doesn't work on 316d.
      03-31-2020, 11:34 AM   #9
xpro
171
Drives: 335XD
I think its not really suitable for anything other then 3.0 twin turbo
My friend had it done some time ago on a 330D F30 and it was nice to drive. The car surges in lower rpm bands.
Where in a 335d the low rpm band is eliminated by using the small turbo.
      03-31-2020, 12:35 PM   #10
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Yes I know.
But I wanted it to show the gears in D. For eg. D1, D2, D3, ...
      04-01-2020, 06:56 AM   #11
xpro
171
Drives: 335XD
I just realised that my SVT_soll.xml file was empty? Would that be correct?
I just pm'ed my ist.xml file
      04-01-2020, 07:25 AM   #12
anielsen71
Denmark
559
Drives: F36 435xd
Yes I know.
Use xHP instead.
That gives you the gear indicator
Brgds
Allan
‘15 F36 435xd Gran Coupé
Ex: E46 330d, E91 330dA
      04-01-2020, 08:40 AM   #13
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
That's 159€, find it quiet to much though for just showing D1/2/3 etc.
If it was available with Esys I would've done it right away!
      04-01-2020, 01:06 PM   #14
xpro
171
Drives: 335XD
Right, Im getting closer!
The problem I think is that the previous Alpina guide is based on Esys 3.27.
I am using V3.34 as new psdzdata isn't compatible with V3.27.
Take a look at the photos.
1.In my step I first read SVT in top window and save as SVT_ist.xml
2.Select shipment istep and complete flash then calculate.
3. This part is different! In the 3rd window ( SVT update, the file is immediately created after I calculate the complete flash.
I can save it as _soll.xml but this file is blank!
So I can press Read (V..( SVT as actual target)
Then save the SVT_soll.xml again, and this time the file is created and I can now see the ECU is blue and red!
4. Tal calculation and save
And now to flash process.
I get a warning message.
EGS flash is available this time, but missing blflash.
So I cannot flash the alpina again.
If someone please did this flash using esys v3.34 be greatly appreciated!
Thanks
      04-01-2020, 02:28 PM   #15
atzebmw
Germany
588
Try it without blFlash.
      04-02-2020, 04:36 AM   #16
Saroo
Drives: BMW 335D
Hi did you get this sorted? I’ve been having the same issue
      04-02-2020, 04:37 AM   #17
xpro
171
Drives: 335XD
Not yet.
I will try to flash today
      04-02-2020, 04:45 AM   #18
Saroo
Drives: BMW 335D
Not yet.
Please let me know how you get on thank you
      04-02-2020, 05:18 AM   #19
xpro
171
Drives: 335XD
will do
      04-02-2020, 01:45 PM   #20
Saroo
Drives: BMW 335D
Hi I’ve been messing with this again today and realised If I set my i-step to the same as in the screenshot f020-14-11-502 and then follow all the steps I can get to the end and it shows the EGS module to flash in the last step and I can select swdeploy and cdDeploy but not biflash.
My actual I-step is f020-17-07-502. Would flashing the vehicle like this brick it or would it work please unsure.
      04-02-2020, 03:01 PM   #21
atzebmw
Germany
588
https://f30.bimmerpost.com/forums/sh...6&postcount=15
      04-03-2020, 01:11 PM   #22
Saroo
Drives: BMW 335D
Hi still no success I’ve uploaded my FA file to the link below would appreciate is someone would edit it saving the files needed so I could flash it on my car using my pc please really would appreciate that my I-step version is f020-17-07-502 thank you.
https://mega.nz/file/bckwRCRQ#Q1F0xd...Wp_rRy_UJFonfY
f30post
