2010 2011 BMW 5 Series Forum F10 Module SVT removal/delete... How? Help please. |
03-28-2020, 08:40 PM | #1 |
Rep 20
Hi everyone,
I'm not sure if this can be done but the options to delete are listed on E-SYS so maybe possible? (it just won't allow me to delete for some reason.) I would like to remove a module from the car and potentially program another if needed so it doesn't create any errors when it no longer see's the data for it. The module in question to be removed is the GHAS and I am not sure if the DSC requires programming or coding so it doesn't show a communication error with the GHAS once it has been removed? (if it can be deleted that is..) A simple VO change/removal won't work as it is not in the SALAPA list. FDL coding will not solve this issue either as there is nothing in the DSC/KOMBI CAFD file to stop voltage monitoring of the GHAS etc... Can this be done? Any help would be appreciated, thank you! |
