F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Module SVT removal/delete... How? Help please.
Studio RSR
      03-28-2020, 08:38 PM   #1
Marvins
Marvins's Avatar
Drives: M5 F10
Hi everyone,
I'm not sure if this can be done but the options to delete are listed on E-SYS so maybe possible? (it just won't allow me to delete for some reason.)
I would like to remove a module from the car and potentially program another if needed so it doesn't create any errors when it no longer see's the data for it.
The module in question to be removed is the GHAS and I am not sure if the DSC requires programming or coding so it doesn't show a communication error with the GHAS once it has been removed? (if it can be deleted that is..)
A simple VO change/removal won't work as it is not in the SALAPA list. FDL coding will not solve this issue either as there is nothing in the DSC/KOMBI CAFD file to stop voltage monitoring of the GHAS etc...
Can this be done?
Any help would be appreciated, thank you!
      03-29-2020, 04:42 AM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
The best way would be to remove the old module and immediately install the new one.
But what is GHAS?
Maybe there is a way to code it out.
      03-29-2020, 03:28 PM   #3
Marvins
Marvins's Avatar
Drives: M5 F10
But what is GHAS?
Regulated differential lock (GHAS)
It cant simply be removed from what I have seen but I have been told it is possible to program the DSC (ABS) module to remove its need to be there.
I.e it no longer requires the use of the temperature sensor, rotor position sensor and servo motor for differential locking under certain loads etc...
f30post
