E90 coolant ?
03-27-2020, 03:35 PM | #2 |
700
Rep 1,227
https://lmgtfy.com/?q=n54+coolant+capacity
answer: Approximate Engine coolant capacity: 6.2 liter / 6.6 U.S. qt / 5.5 imp. qt |
Antetokounmpo1551.50 |
03-27-2020, 06:09 PM | #4 |
1903
Rep 6,968
03-27-2020, 06:20 PM | #6 |
2659
Rep 6,290
03-27-2020, 06:38 PM | #8 |
17
Rep 141
03-29-2020, 12:49 PM | #10 |
27
Rep 87
I read somewhere on here a long time ago that it increases the changes of some sort of plastic bits inside the cooling system breaking free and clogging something, or something along those lines. I do not remember the details. But one user went to great lengths explaining why you should never drain/fill your coolant system.
Anyone might have some more info on this? |
03-29-2020, 01:36 PM | #11 | |
126
Rep 246
Coolant may deteriorate plastic or even react with metals which it wouldn't if correct coolant is used. He might have meant that fresh coolant may wash loose contamination that have settled in dirty coolant system. |
Moisture27.00 |
03-30-2020, 11:28 AM | #12 | |
2440
Rep 4,330
regularly draining and refilling the system with fresh coolant is how you keep electrolysis from happening in your cooling system. it's literally part of the recommended maintenance. |
03-30-2020, 12:35 PM | #13 |
700
Rep 1,227
Yep I agree its what you should be doing on a regular basis, at least if you care about your car that is.
