Rear Tire Issue? OR Rear Allignment Issue? Rearend feels like it's moving around.
03-26-2020, 12:55 PM | #1 |
2001
Rep 3,731
A few weeks ago I dropped my rear subframe in my 07' 335i and did solid poly subframe bushings, installed the M3 rear control arms from FCP, and put on a new rear set of Firehawk Indy 500 tires (replaced the worn out Michelin PSS that were on the car).
The car drives and handles great now, and the "Waggle" from the rear under hard acceleration is gone. I do have a new issue now though......when I'm on the highway, it seems like the car wants to walk around a little bit....following the grooves in the road. It goes nice and straight if I let off the wheel, but it just feels like you are constantly having to make small little corrections.....its almost feels like you are driving in heavy wind. It didn't do this with the old tires, worn out bushings, and oem control arms. I didn't get an alignment done after I installed the rear arms, but they shouldn't have changed anything....right? The Firehawk 500 tires have some pretty good groves in the tread, so I'm wondering if this might be the problem? Any ideas? Thanks!
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
03-26-2020, 01:16 PM | #2 |
3008
Rep 1,798
I'm running the same tires on my summers and experienced the same thing. I do remember a slight tram-lining at highway speed but went away as the tires broke in after a couple hundred miles. If it isn't temperature or alignment related I would just give it some time to break in.
I'm no expert but strongly believe an alignment should be done when replacing those suspension parts. |
03-26-2020, 02:08 PM | #3 | |
2001
Rep 3,731
If those were the arms that affected toe or camber...then yes, I would get it aligned. Bot those arms "shouldn't" affect anything regarding alignment. I guess at this point, I'll just put some more miles on the car and see what happens.
03-28-2020, 05:33 PM | #4 |
22
Rep 111
I have these tires and it took almost 1000 miles for them to stop the tramline effect while driving.
Also, they flatspot overnight when parked. I raised the pressure to 38 psi and they dont do it anymore.
Buckle up, Its the ride of your life.
03-29-2020, 01:02 PM | #6 |
367
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
Hows the indy 500s and what made you get them? How are they compred to your pilot super sports? I wanted to get thae last year but got all seasons instead.
03-29-2020, 02:18 PM | #7 |
3008
Rep 1,798
Indy 500s are cheap here, about 1/2 price or less than the PSS. I'd say unless you're constantly tracking the car you wont notice a huge difference in dry traction. The wet traction actually isn't as bad as the tread pattern would make you think it is, but not great either.
I'm in the summer / winter > all seasons camp because I live in a snowy area, I'll never buy all seasons anymore as long as I live here. If I lived in the south or somewhere that doesn't get below 0C or 32F I wouldn't bother with all seasons either. |
03-29-2020, 07:49 PM | #8 | |
367
Rep 780
03-30-2020, 08:09 AM | #9 | |
2001
Rep 3,731
Aside from the loose feeling on the highway (which seems to get less and less the more I drive the car), I really like them. I think on the set, I saved several hundred dollars vs the PSS's. It's good to hear that those tires tent to track around on the road when they are new....I'm not so paranoid about it now. I still need to get the alignment checked though. |
03-30-2020, 08:10 AM | #10 |
2001
Rep 3,731
The new Indy 500's are much quieter than the worn PSS's I had.....if that helps you out at all.
03-30-2020, 04:39 PM | #11 |
Robot
1685
Rep 2,191
I'm not familiar with those tires, but it seems from the comments that they need some time to break in.
Get the alignment done, it's needed and you won't regret it. I replaced my suspension a few months ago ago but had been putting off getting an alignment until the old tires wore out. Well they finally wore and it was time for an alignment which I had done last week. I don't have the exact specs off the top of my head, but the rear was so messed up with excessive negative camber and toe out. The alignment made a huge improvement in handling and feel of the car. |
03-30-2020, 08:53 PM | #12 | |
367
Rep 780
04-06-2020, 02:14 PM | #13 |
2001
Rep 3,731
***UPDATE***
Well, after putting some miles on those new Indy 500 tires on the rear.....it's finally starting to feel back to normal again. I guess it was just the new tires needing to be broken in. I'm still going to have the alignment checked...but at this point, everything feels great.
