TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > ***help please*** crank pulley (harmonic balancer bolts)
      03-26-2020, 03:17 AM   #1
Wazman999
Wazman999's Avatar
403
Drives: F31 335D xDrive
Unhappy ***help please*** crank pulley (harmonic balancer bolts)
Morning guys
I have a 2009 320d (N47)
My crank pulley (harmonic balancer) needs replacing - see photo....
I simply cannot undo the bolts...
Ive tried but it just spins the engine. tried impact gun no luck
Ive been advised to do it in 6th gear (manual) so the engine cant spin
The only threat i can find says to lock the engine with an allen key but that was a 335 engine, not my 320d N47....
Any help greatly appreciated
      03-26-2020, 05:39 AM   #2
Serf27
Serf27's Avatar
2851
Drives: 335i
They sell locking pliers with a chain on the end of them that wrap around big round things and hold them in place.
That will work.
Maybe some rust penetrant too.
      03-26-2020, 07:43 AM   #3
relative4
611
Drives: '08 335xi E90 MT stage 1+
A chain wrench will mar the pulley. That's fine if you're throwing it away, but for installing the new one, a strap wrench is better.
      03-26-2020, 07:46 AM   #4
relative4
611
Maybe this?
https://www.ecstuning.com/b-genuine-...UaApW2EALw_wcB
      03-26-2020, 07:55 AM   #5
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
Originally Posted by Wazman999 View Post
Morning guys
I think a possible way you could do this is have a breaker bar with a socket and put it on one of the bolts, then keep the breaker bar in place maybe someone hold it or make it get stuck against the chassis whatever it takes to keep it from letting the engine turn. Then go around trying to undo the other bolts with another tool. for your own good and mental health.. soak those bolts in penetrant every 10 minutes you spent search on the forums also make sure the sockets are very well seated, you don't wanna strip one of those
      03-26-2020, 09:29 AM   #6
nsjames
2440
Drives: 08 328xi Touring
I am unfamiliar with that engine.
but on most things I would pull the starter a and jam a big pry bar into the flywheel teeth while a friend undid the bolts.
      03-26-2020, 09:43 AM   #7
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Kroil oil - soak them for 24 hours
Torch - yellow gas...
Also, I would not replace them with OEM bolts. You can get SS bolts to do the job. You just need the thread count
The problem is that e-Torx strip very quickly.
So, you will need back up plan for sure.
Irwin makes a good stripped bolt kit.
IRWIN Bolt Extractor Set, 5-Piece (394002) https://www.amazon.com/dp/B000QW6K8I..._admFEb9P4QWJK
Or find a small cutting tool for a dremmel you can get in there and sheer the bolt heads off. Once the flywheel is off, you can take the remaining bolt out with a set of lock pliers.
      03-26-2020, 10:58 AM   #8
Wazman999
Wazman999's Avatar
403
Talking *** update ***
bolts off.......
just needed to be in 6th gear
thanks guys
      03-28-2020, 07:26 PM   #9
E92William
1998
That would have sucked with an automatic..
