BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Windshield replacement questions to ask installer?
      03-25-2020, 05:02 PM   #1
Dravit_M340i
Dravit_M340i's Avatar
129
Drives: 2020 BMW M340i Dravit Grey
Hi All,
Bought my M340i used with 3000 miles (loaner trade in). Driver side windshield had a nice crack in the center so I negotiated a windshield replacement when I purchased the car. Its being replaced by the dealership I purchased it from (Certified Benz and Beemer) and they have fantastic service reviews. Still nervous about the process and sensors. I asked if it would be OEM and was told yes because its a 2020. What other questions should I make sure to ask? Sensor calibration? anything else? Thanks!
      03-25-2020, 05:05 PM   #2
themnmd
themnmd's Avatar
1691
Drives: 23 X5MC
recalibration of any sensors should be included with replacement imho
      03-25-2020, 05:12 PM   #3
Dravit_M340i
129
I believe it will be and I will 100% make sure I ask that. Thanks!
      03-25-2020, 05:58 PM   #4
ubchariot
102
Drives: BMW M340i xdrive
Make sure to ask them to seal the windshield tightly so that the noise level won't increase with the replacement.
      03-25-2020, 06:02 PM   #5
Burrcold
5297
Drives: 2024 M3 Comp xDrive
Just get 100% clarification that it will be OEM (BMW badging on it) and not OE...there's a difference and they will try to install OE glass if they can.
      03-25-2020, 06:02 PM   #6
EXE46
EXE46's Avatar
2100
Drives: 2020 M340i RWD Aka New E39 M5
Also I assume you have heads-up display. Make sure it's working as before.
Prior's: E36, E46 x2
      03-25-2020, 06:10 PM   #7
premier3is
premier3is's Avatar
1632
Drives: 2019 BMW 330i M-Sport
Just look for the BMW badge on the glass and make sure it's recalibrated.
Other than that you'll be fine.
      03-25-2020, 06:55 PM   #8
Dravit_M340i
129
Thanks, I appreciate the responses. I do not have the head up display so don't have to worry about that.
      03-25-2020, 10:16 PM   #9
cnichols138
X3M Comp is a beast
89
Drives: 2022 BMW X3M Comp
Mine is cracked as well due to a rock. I hate to see it. I am worried if I have it replaced they will force me to a non OEM windshield.
BTW what needs calibrated after replacement?
      03-25-2020, 10:20 PM   #10
DG20
DG20's Avatar
967
Drives: M340i
Got mine replaced last week for $2450, insurance covered most of it. So far, everything seems fine.
Instagram: @dg_g20
      03-26-2020, 12:47 AM   #11
Dravit_M340i
129
$2450 wow. Now I'm a little worried I wont be getting OEM.. not sure what to do if not.. any suggestions? Do I hold off if not OEM and make a claim through my insurance. My job pays for my insurance and I know we have glass coverage but not sure if they will only cover a certain amount. What risks are there if replacing with non OEM glass? Had 3 windshields replaced on my old car and last one was not OEM but all sensors and everything worked fine and glass actually seemed stronger than the OEM.
      03-26-2020, 02:08 AM   #12
premier3is
premier3is's Avatar
1632
Stick with OEM, this car is still pretty new so I'd only want OEM equipment anyways.
As far as why calibration is needed is because it's for your ADAS (advanced driver assistance systems), so essentially it's for maintaining the accuracy of the safety features in the vehicle. A non OEM glass probably isn't manufactured to the same specs as the OEM one so a calibration is 100% needed once you install the windshield. It's essential regardless of what glass you end up going with.
And yes, this is an expensive replacement. You're looking at 2k+ probably from what I've seen and read. Got to pay to play!
      03-27-2020, 01:21 PM   #13
Dravit_M340i
129
Update... just called the dealer where I purchased the vehicle and the glass is 100% OEM. I was told since it is 2018 or newer they wont use non OEM replacement glass. They will also do all the calibrations at the shop! Windshield replacement on Monday and Ceramic Pro ceramic coat scheduled for Tuesday!
