Over heating?
03-22-2020, 04:45 PM | #1 |
Ghibli
Rep 18
Over heating?
Hey all, I own a 2007 bmw 335i coupe with 92,000 miles on it. My car over heated and then my mechanic replaced the water pump AND thermostat a couple weeks ago. Was driving it the other day and it started over heating again. Filled it with coolant, didn’t give me a light, and now it’s over heating again. I opened the hood and saw some coolant underneath the coolant reservoir although I’m not sure if it was leakage from when I filled it earlier today. Any ideas on why it would be over heating even if I just replaced the pump and thermostat? Thanks in advance.
-Greg
G
03-22-2020, 07:18 PM | #2 |
31
Rep 112
Drives: 2011 BMW 335i Sedan
I think your coolant reservoir is leaking if you see coolant underneath it... Try to replace that as well and see what happens.
03-25-2020, 09:07 AM | #3 |
Ghibli
Rep 18
03-27-2020, 06:27 PM | #6 |
1082
Rep 1,676
I would think if it leaked enough then a low coolant light should come on. However, a cracked reservoir also means the system will not hold pressure, and this can cause a boilover.
03-30-2020, 10:34 AM | #7 |
Ghibli
Rep 18
Okay I'll try that, thank you.
G
03-30-2020, 10:38 AM | #8 |
Ghibli
Rep 18
Yeah i think I've gotten a low coolant light before (my rear turbo leaks) and I didn't get that light. I only got the yellow temperature light followed but the red temperature light and then limp mode after that. So maybe it is cracked and won't hold pressure?
G
03-30-2020, 02:26 PM | #9 |
Ghibli
Rep 18
I'm not sure if it's the cap or not. The cap would cause the car to overheat?
G
03-30-2020, 02:44 PM | #10 |
3058
Rep 3,910
Cap has a pressure relief valve built in - if that doesn't hold pressure, the water in the system will boil at a much lower temp than it needs to...and result in overheating.
03-30-2020, 04:30 PM | #11 | |
2440
Rep 4,330
a cap is worth a shot, but someone needs to pressure test the cooling system. if it passes a pressure test with no leaks, then replace cap. your previous overheat may have led to an increase in the pressure the system had to contain, and damaged something. |
03-31-2020, 08:04 AM | #12 | ||
Ghibli
Rep 18
G
Tags |
n54 335 335i e92 e90, overheating e92 |
