Another Bimmerlabs 330i tune thread
03-21-2020, 12:45 PM | #1 |
Rep 18
I know this discussion has already been run into the ground at this point so I'm going to get straight to the point. I have a 3IM coming in the mail in a couple weeks and am going to attempt the 330i flash tune from Bimmerlabs. I just finished configuring the program but I'm not sure it's correct. There are a few red flags that have me concerned.
If this is all jumbled up I'll go ahead and remove all of the files and restart the installation. Better to find out now than during the flash Thanks! |
03-22-2020, 11:14 AM | #3 |
367
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
What is happening to the vehicle? My car already comes with the 3intake manifold because n51. Can i do this also?
03-22-2020, 02:12 PM | #4 | |
Rep 18
My problem here is that I'm not sure if the tuning files were placed in the correct folders. I want to find out now so I can reinstall before the tune if needed. |
03-22-2020, 10:23 PM | #6 |
226
Rep 290
03-22-2020, 11:30 PM | #7 | |
Rep 18
03-23-2020, 12:34 PM | #9 |
Rep 18
Yes I did. I was extremely meticulous with it. The part that threw me I guess was Bimmergeeks saying to delete and replace the folders, but Bimmerlabs saying not to. However, if I didn't delete and replace the folders the programs would not open.
03-26-2020, 09:31 AM | #11 |
2440
Rep 4,330
as long as you've imported the files into winkfp then it should work.
MPOWER52664753.00 |
03-28-2020, 12:27 AM | #13 |
Rep 18
03-28-2020, 01:11 PM | #14 |
2440
Rep 4,330
you could read a module, but really if your ediabas works and you've imported the files it will work.
if it doesn't, then you can investigate it. the software is kind of works or doesn't. if it doesn't, it won't do anything. likely the issue you'll have is the batch file not copying files into directories. copy/paste them and then the batch file works. |
05-17-2020, 11:38 PM | #15 | |
149
Rep 161
