If you've seen this before, you've seen a lot......
03-19-2020, 03:08 PM | #1 |
483
Rep 681
Took the car out a weekend ago and 1 mile from the house, I get to a stop sign and hear a clunk. Try to pull over, car won't move fwd. I am able to go in reverse with some resistance, but make it to the side of the road where I find a caliper through my wheel. That's where the fun began because then I had to get a wheel-locked car towed and dropped. In the process the brake line snapped.
Loved this car, but this was my knock out punch, lol. |
03-19-2020, 03:23 PM | #4 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Caliper bolts sheared, probably were not torqued then backed out
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
03-19-2020, 06:50 PM | #6 | |
2697
Rep 4,031
Of COURSE it ripped the brake line loose. That and the RR Pad Wear Sensor wiring were the only things attached to the caliper that were still connected to the car. Didn't you hear a squeal or grinding from the RR when you came to a stop? The Drilled & Slotted "Boutique" rotor has rings/ grooves in it near the outer edge. Thank your "Lucky Stars" that you weren't doing 80+ when it came loose. You might consider "adjusting" your concept of auto maintenance, and take it seriously. As a piece of machinery that can kill you and other people if NOT properly maintained or worked on by people who know what they are doing and take the time to do it right. George |
Bobh5952.00 |
03-19-2020, 07:00 PM | #7 |
Kind of a Big Deal
167
Rep 857
George makes an interesting point. After years of reading this forum I have *yet* to come across an example of someone muffing a repair!
03-20-2020, 06:31 AM | #8 | |
483
Rep 681
The tow guy and me realized the wheel was stuck due to caliper and brake line. There was no squealing until after the clunk. The clunk was the caliper going through the wheel. I was on the side of a busy road with part of my car stuck out on the road and the back half on a decline, plus my car is lowered. The amount of crap I'd have to go through to get the car out without damage was just not worth it. Anyways the really shatty part of this, is the car has been riding sooooo good. I've been wanting update my weekend car to an IS so this will probably push me to do that. |
03-20-2020, 07:27 AM | #9 | |
38
Rep 95
Sorry to hear about you problem OP. |
03-20-2020, 11:13 AM | #10 | |
General
17315
Rep 18,737
Getting rid of the car based on poor craftsmanship with a brake job seems a bit silly and really just an excuse. |
SabineBimmer765.00 |
03-20-2020, 11:15 AM | #11 | |
General
17315
Rep 18,737
03-20-2020, 11:36 AM | #12 | |
2697
Rep 4,031
My selfish purpose for following Forums is to LEARN something about my car. So for "Lessons Learned" purposes, I wonder if you can offer any insight as to HOW or WHY the caliper came loose? Have you had a chance to determine WHY the caliper came loose? Did BOTH guide pin bolts fall out or is ONE or both broken -- if just one broken & still in caliper, which one (top or bottom)? Did you notice any "Clunk" when slowly moving forward or backing, as in parking? Was there ANY unusual sound or braking action at all before the last stop? Thanks for any insight you can provide. Please accept my apologies and condolences. George |
nerovega37.50 bobbytomorow9.50 |
03-20-2020, 12:16 PM | #13 |
45
Rep 158
Drives: 2011 328i
I've had something go through a rim before, but not like that!
Mine was I hit something on the highway at zero dark thirty in the morning and it practically lifted the whole damned car off the ground (I know the entire passenger side came up because the back tire didn't hit it). A mile or so down the road I get the "low tire" indication on the dashboard (thankfully that was when I still had run flats). I never expected the rim to be destroyed, but it was. Just not that bad! |
03-20-2020, 01:28 PM | #14 | |
483
Rep 681
To the other poster about how I tighten. I'm a pretty good gauge on torquing down brake components and I typically finish off with a torque wrench. I also test my vehicle afterwards. Purchased a brake package on black Friday, installed shortly after receiving. have been driving problem/noise free since this incident. The obvious culprit is me, but I may never know the reason. I know this will make me over the top safe going forward and I think I'm already pretty thorough. |
03-20-2020, 02:03 PM | #15 | |
2697
Rep 4,031
I had ASSumed from OP's text that the caliper guide pin bolts came loose. THAT is the entire carrier coming loose (the Guide Pins are still holding the caliper to the CARRIER). WHEN was the CARRIER ever removed, by WHOM & WHY? When the discs were changed? Were New Bolts used, or at least proper application of Loctite? BEFORE selling that car to someone else, CHECK/REPLACE ALL CARRIER BOLTS. Here is RealOEM diagram of system: https://www.realoem.com/bmw/enUS/sho...diagId=34_1476 Here are TIS Procedure for Removing & Installing Brake Discs, and the Instructions for NEW BOLTS and Torque Spec: https://www.newtis.info/tisv2/a/en/e...brakes/GR2uYhS https://www.newtis.info/tisv2/a/en/e...brakes/5VxrBpt NOTE: Replace self-locking or microencapsulated screws; Torque 110 Nm THAT is frightening. George |
03-20-2020, 02:24 PM | #16 |
126
Rep 246
I know a guy who can weld that rim.
The caliper bolts we just tighten as hard as possible but not so hard that the tools break. I think the bolt snapped for unknown reasons so it's unfortunate. Last edited by Captain Buumer; 03-20-2020 at 02:30 PM.. |
03-20-2020, 02:28 PM | #17 | |
483
Rep 681
03-21-2020, 04:27 AM | #18 | |
General
17315
Rep 18,737
By the pic, you are mostly already halfway through the rebuild. ASSuming the hub is not damaged. |
03-21-2020, 10:12 AM | #19 |
33
Rep 70
Do you even have to remove the caliper carrier (and bolts) to remove the Rear Rotor/Disc? I honestly can't remember and if so, I certainly never replaced the bolts.
03-21-2020, 08:58 PM | #21 |
367
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
I had a miata with a rim that was welded from my friends brother, came right of and broke in half on a big street. I was legit 3 wheeling in a turn and scraped the whole rotor and caliper dislocated. Shocks and mounts were fine.
03-22-2020, 11:10 AM | #22 |
General
17315
Rep 18,737
Yes, the carrier has to be removed. I've never replaced the bolts. Just use Loc-Tight Blue
