03-14-2020, 06:34 AM | #1 |
107
Rep 411
So, As some of you may know I was having major issues with ignition timing and draggy times on my F90 Comp. I was also having issues with my car starting, wherein car would start and, in some. Instances, immediately shut off after turning on the ignition. This was a faulty fuel pump issue. Bmw replaced, and car is running much better. I bought HCP stage 1, scrapped my JB4, and also had Mo at DME (who is fantastic and comes highly recommended) build a custom flash map (slightly more aggressive) for my car (at least until I get my downpipes, which are on the way). Wanted to share some preliminary results
Here is HCP Stage 1 60-130 Bone Stock (I have M Performance Exhaust and the Steel Breaks with the Carbon Fiber Roof). This is with 93 Octane Pump Gas (see time below in the 7.61s). I wasn't able to capture the quarter mile and 0-60 times. This was on a very cool day for south Florida. This was from a roll. Also, here are times - 0-60, 60–130, and quarter mile, a single quarter mile run from a dig on the DME Custom Tune. Car is otherwise bone stock. This was run on half a tank of 93 octane + 1 gallon E85. It was relatively hotter day in So Fla. Car is feeling much much better downpipes should be here Monday. Stay tuned |
03-14-2020, 07:08 AM | #4 |
463
Rep 524
03-14-2020, 07:09 AM | #5 |
107
Rep 411
I'll need to get an HCP quarter run. But DME is having issues loading their map into BM3 platform. So it's a bitch for me to toggle back and forth currently
I actually think the quarter time is quite good for just a flash on essentially 93 octane. No other mods Trapped almost 133. I think that's faster than that one guy at PBIR with hydra and every other mod known to man. Good work Mo |
03-14-2020, 07:11 AM | #6 | |
463
Rep 524
03-15-2020, 12:30 PM | #7 | |
575
Rep 754
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
r33_RGSport13043.50 |
03-15-2020, 02:50 PM | #9 | |
3619
Rep 4,532
Mcc420475.00 |
03-17-2020, 06:57 PM | #15 |
463
Rep 524
03-19-2020, 10:58 AM | #20 | |
575
Rep 754
Another 0.5 is a lot... haha Good Luck though I think under 7.0 is pretty solid stage2 and with good temps and DA and fuel then mid 6's are good. For race fuel you can get to lower 6's or maybe high 5.9 with custom tune, negative DA and downhill...haha Which stg2 tune did you run?
03-21-2020, 10:50 PM | #22 |
107
Rep 411
This is about a 0.15 improvement ... this was from a dig, and in relatively hot Florida weather (about 77)...
Only on 93 pump .. let's see what happens if I had a gallon of e85 and get a cold day? |
