The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Video Bmw 335i engine done-zo or normal?
      03-13-2020, 11:21 PM   #1
noble335i
Drives: BMW 335i
What you think?
      03-14-2020, 08:22 AM   #2
clegg
87
Drives: 335i E92, 435i F32,X5 F15
The 335 engines are noisy AF without the plastic engine (beauty) cover on because of the direct injection.
I replaced the spark plugs and coils and went for a test drive with the cover off. Sounds almost diesel like. I could not get that cover back on quick enough. I thought something was wrong.
How does yours sound with the cover installed?
      03-14-2020, 09:23 AM   #3
noble335i
Drives: BMW 335i
Well I’ve recently found oil in my coolant, after changing my alternator ($600 at local parts store) I had to take off the ofh and it leaked oil into the inlet. So flushed coolant and put all new and it sounds weird. Just taking extra precautions. Good thing about it that I noticed when I changed oil is it was chocolate milk
      03-14-2020, 09:31 AM   #4
noble335i
Drives: BMW 335i
Also I’m having problem with smoking I know I have a bad vacuum pressure hose I’m not getting a vacuum on decel. Not sure if that would cause smoke
      03-14-2020, 11:06 PM   #5
Moisture
27
Drives: 2015 Mazda 6, 2020 Lexus NX300
sounds healthy to me. but not always possible to tell unless you rev it up a little.
      03-15-2020, 09:42 AM   #6
clegg
87
Did you replace the gaskets when you had the OFH off?
On the video, there appears to be a loose vacuum line above the oil filter.
