Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Vibration at rear of engine after hard acceleration. Torque converter?
      03-12-2020, 08:42 PM   #1
vilord
488
Drives: E91, Tundra, TT, SV650
My 6AT car occasionally has a hard downshift when rolling up a hill no load.
It also has a bit of driveline vibration under acceleration at about 40mph.
At 106k miles, I'm sure it needs a transmission fluid/filter change and flush.
Yesterday on my way home I gunned it down a little straightaway near my office, everything functioned as it should, but when I idled to a stop a mile or so later, everything was vibrating something fierce. Get up past idle and vibration is gone.
Can't be a u-joint, because I was stopped, but it felt similar.
Popped the hood and the vibration was coming from the back of the engine.
Worried I fucked something in the engine I decided that the best thing to do is to duck into whole foods and buy some dessert.
When I came back out and started it back up, vibration was gone.
Could this be something wrong with the torque converter? Or dirty fluid getting stuck in a TC fluid passage?
Jesse
      03-12-2020, 09:05 PM   #2
NinetyEight740
NinetyEight740's Avatar
231
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Check engine light come on? How do you see movement at rear of engine only?
      03-12-2020, 09:26 PM   #3
vilord
488
No check engine light.
I can't see vibration, but I can feel it if I put my hand on the front vs the rear of the engine, and can also hear it.
Jesse
      03-12-2020, 09:49 PM   #4
Moisture
27
Drives: 2015 Mazda 6, 2020 Lexus NX300
You need to service your transmission. I wouldnt suggest doing hard acceleration .
      03-13-2020, 12:01 AM   #5
tlow98
2188
Drives: 2009 E91, 2014 F15 x35i
sounds like a misfire that wasn't logged.
Also, change your fluid. That ZF box was supposed to have it at 60k.
      03-13-2020, 01:44 PM   #6
dsjr2006
157
Drives: '01 E39 540iA, '09 E90 M3
2010 BMW 335i  [0.00]
2001 BMW 540i  [0.00]
It could be lots of things, including a bad motor or trans mount.
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
      03-13-2020, 01:56 PM   #7
MineralweissIS
MineralweissIS's Avatar
47
Drives: 2012 Mineral White 335is
2012 BMW 335is  [0.00]
+1 check the condition of your mounts.
'12 335is Mineral White Metallic / Saddle Brown / DCT / Nav / Cold / Premium / Convenience / H-K
      03-13-2020, 06:20 PM   #8
nsjames
2440
Drives: 08 328xi Touring
if it's a 328 it's the GM, but they still recommend a 100K mile interval for fluid and filter under normal conditions.
it certainly cleared up any part throttle shudder that mine had at 101K miles.
I would service the transmission and not worry about it until it reappears, then diagnose it.
sounds like coil things to me.
      03-14-2020, 12:33 AM   #9
tlow98
2188
ah thought this was a turbo car! 07 328 - i don't recall if the zf box was still lingering then? I think the general rule of thumb was 325 = zf, 328 = gm
      03-14-2020, 05:35 AM   #10
vilord
488
Sorry, didn't specify, this is the 2009 328xi, so 99.9% it has the GM. Glad to hear it has a 100k schedule.
I'll get the trans fluid changed this week, and see if it clears up. Thanks!
