2C31 code
03-12-2020, 07:05 PM | #1 |
70
Rep 145
Drives: BMW M4 and BMW M3 E46
2C31 code
2011 BMW 328i with 2C31 code.
I recently replaced both pre cat O2 sensors with Bosch 11787558055 and 11787558073 after fault code 2C2B. The O2 sensors were installed correctly. Does anyone have a suggestion to the 2C31 code? This car is starting to get on my nerves!! |
03-12-2020, 09:06 PM | #2 |
654
Rep 1,893
Assuming your new sensor is not faulty, the next thing I'd look for would be a small exhaust leak. Mostly likely a gasket but also possibly an improperly tightened O2 sensor. Smoke or pressure test is pretty easy.
03-12-2020, 11:19 PM | #3 |
70
Rep 145
The car just through a second code, 2CB6, O2 sensor after cat conv.: Signal fixed lean.
post cat O2 sensor bank 1 or 2 stuck lean? |
03-13-2020, 12:59 AM | #4 | ||
2697
Rep 4,031
N52 | P2096 | 2C31 | DME: Oxygen sensor control | MSV80 http://www.bmwfault.codes/XMLDiagVie...cANQA5ADAANAA= 2CB6 | DME: Oxygen sensor after catalytic converter: Signal fixed at lean | msd80 http://www.bmwfault.codes/XMLDiagVie...MAOQAxADAANAA= George |
03-13-2020, 05:45 AM | #5 |
654
Rep 1,893
I'd suspect that as well except:
1) the OP replaced the pre-cat sensors because he first observed a 2C2B code 2) the OP made a point of stating that the new sensors were installed correctly. 3) All codes are bank 1 - if there was a connector swap on the pre-cats there'd likely be codes on both banks. |
03-13-2020, 10:36 AM | #6 |
70
Rep 145
The connectors have not been reversed by me for sure. The previous owner could have reversed them but I have driven +30K miles since purchase.
Wouldn't the fault codes showed up much earlier if the previous owner reversed the connectors? |
03-14-2020, 05:09 AM | #7 |
654
Rep 1,893
