N54 Valve Cover Question: Need Answer ASAP
03-12-2020, 01:17 PM | #1 |
15
Rep 184
Hey guys,
I'm currently in the process of replacing the valve cover gasket on my 2008 BMW 335i. I have begun removing the bolts for the valve cover, and 2 of them have come out of their "sleeves" in the plastic part of the valve cover. (See pics attached if you don't know what I'm trying to say) My question is, can I just slide them back in and reinstall the valve cover normally, or am I going to have to bite the bullet and buy a whole new valve cover and be car-less for a week? Thanks! |
03-12-2020, 01:30 PM | #4 |
15
Rep 184
03-12-2020, 01:36 PM | #5 | |
2657
Rep 6,290
Don't know if it cracked because of stress in removal or what but yeah. Also if cover is old the internal pcv stuff maybe alal gunked up. |
03-12-2020, 03:57 PM | #7 |
123
Rep 331
Those bolts were easily pulled out when I did my old valve cover but saw that the new bolts stayed inside the new valve cover. Idk if that has anything to do with how well the cover was sealing but it could be a sign for a new cover.
03-12-2020, 03:59 PM | #8 |
15
Rep 184
I just ordered a new one from Uro on ECS. Hopefully it arrives soon.
03-12-2020, 08:11 PM | #9 |
87
Rep 301
Be sure to install an upgraded pcv valve in there.
03-13-2020, 07:17 AM | #10 |
479
Rep 1,196
I was going to say you're better off buying an aluminum one for a few hundred more $$ to ensure it doesn't crack ever again
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
03-13-2020, 07:26 AM | #11 |
2657
Rep 6,290
Bimmer_Engineer1043.50 |
03-13-2020, 09:07 AM | #12 | |
1903
Rep 6,968
One, pay a couple hundred more for an aluminum one and not worry about it cracking ever again. However, the gasket will leak again at some point; it just depends how long. If you used Ultra Black in conjunction with an OEM gasket, it will be 90 to 100,000 miles I bet Two, pay $400.00 for an OEM cover, get the lifetime warranty, but after 100,000 miles it will leak and the idea of it cracking again after 100k is a distinct possibility. Either way, your either gonna change out a gasket or a gasket and a cover. |
