e92 325i Wont start
03-12-2020, 12:47 PM | #1 |
Rep 32
e92 325i Wont start
So my car decided not to fire up one day, called the RAC out he ran the diagnostics and said it was a starter motor problem. So we bump started it and got it home.
Got myself a starter motor from ECP and changed it over, still wont fire up. Ignition comes on lights work ect but the car wont crank. I then decided to get a new battery and it still doesnt crank. I was informed it could be a ground wire, i checked the one from the battery its self and its fine. Can anyone point me in the direction of where the engine ground wires are? as i have a feeling that it could be one of those which have gone with age. The car is on 115000 miles. any help would be great. |
03-12-2020, 01:46 PM | #2 |
700
Rep 1,227
Have you tried scanning the car for any codes? Usually when a starter fails you get a starter malfunction code when you scan with a proper BMW tool.
Also check some of the basics like voltage directly at the started input while trying to start just to make sure there isn't a huge voltage drop etc. |
03-12-2020, 01:53 PM | #3 |
Rep 32
it has been scanned with no fault codes showing up, as i thought it was the clutch safety sensor but thats fine. i have not checked the battery voltage as i dont have a meter for it. was going to check all the earths first if you can point out there they are on the engine?
03-12-2020, 03:51 PM | #4 |
29
Rep 134
I see you're in the UK, shouldn't matter. Look on the driver side, to get a good look at it remove the under skirt, its by the tire under the steering column. From the top not a good view same area. Or cut your wheels so you can see the engine better same area. Its a braided cable about 1 inch wide 12 inches long. And if it's green that's bad. If it's not all there that's bad. If it's bad that's good because that's probably your problem.
03-14-2020, 09:21 AM | #6 |
Rep 32
are there any other ground locations in the engine bay? checked the one just left of the spark plugs its covered in oil due to my cam cover needing a new gasket. how many more are there?
03-14-2020, 01:45 PM | #7 | |||
2697
Rep 4,031
The primary engine ground strap is on the Vehicle LEFT side of the engine next to the Starter (UK Passenger/ US Driver side of vehicle -- YOUR "Near" side -- or the "Far" side in US where anything strange to "America First" types is the "Far" side as opposed to the "Off" side ). However, there is NO need to remove the Splash shield to inspect that UNLESS the application of the Jumper Cable as a Supplemental Ground Strap causes Starter to Engage. If the cable were "green", that does NOT affect its ability to conduct electricity, as that is only external oxidation or Copper Sulfate formation on the outside of the metal strands of the cable. What you do NOT want to see is BROKEN strands of wire which reduces the cable's ability to conduct electricity. If there is NO click from the area of the Starter Motor and Solenoid when START is pressed with Clutch Pedal pressed, then it is most likely that the CAS Module is NOT sending the "Start Signal" to the Starter Solenoid. That is a 12V+ voltage from Pin #22 of CAS Connector X13376 to the Starter Solenoid & Motor, M6510 in this Schematic: https://www.newtis.info/tisv2/a/en/e...system/uNYjfvY That is the circuit diagram for 2007 models built after 3/1/2007 (late 2007 models). If your vehicle has a build date BEFORE 3/1/2007, use this diagram which has slight differences in JB Connectors: https://www.newtis.info/tisv2/a/en/e...system/r14Nexa INPA will allow you to see if "Terminal 50" is energized or if that 12V+ signal is being sent to the Starter Solenoid, WITHOUT having to take things apart. It will also tell you if the Clutch Switch Module is sending the proper signal to the CAS so that it can send the Start Signal to the Starter. INPA allows you to simply connect to the OBD II Socket with a laptop, and see that information on the computer screen (if you know what screens to open in INPA ;-) I presume RAC tried to Crank the Starter with Jumper Cables attached to the Jumpstart Terminals under the hood, BEFORE they "bump started it" which I presume means turned the engine with vehicle moving by engaging clutch on MT vehicle. If that is the case, your battery may be low, but THAT is NOT preventing the Starter from cranking. Even if you do NOT have a multimeter to check battery voltage, there is one "built-in" to your 325i. It is called "Hidden Menu 9.00" and it can display system voltage (battery voltage when engine NOT running or alternator charging). Follow instructions given here: http://e90.wikifoundry.com/page/BC+hidden+menus Hidden Menu is a bit of a pain to use, as you have to activate it every time you turn on ignition. Multimeters are cheap. Here is Amazon UK example: https://www.amazon.co.uk/s?k=multime...f=nb_sb_noss_1 If you don't have INPA for easy testing (Free Download for use on Windows 10 Laptop), you can always test electrically with a multimeter. You would have to remove the E-box cover under the hood, and use the TIS circuit diagram to locate Connector X6011 as identified in this TIS "Installation Location": https://www.newtis.info/tisv2/a/en/e92-325i-cou/SL92ADs As shown in the CAS schematic linked first, that Black wire from Pin #22 of CAS Connector X13376, goes to Pin #1 of X6011, so that should be 12V+ when START is pressed if the Clutch Switch Module is working properly. Here is the TIS circuit for the Clutch Switch Module, and since I do NOT have a MT vehicle, this is my first interpretation of that diagram. I would presume it sends a signal, presumably Ground, to the CAS, Pin #41 of X13376, when the clutch pedal is pressed. I would be interested in knowing how you tested the Cluch Switch Module: https://www.newtis.info/tisv2/a/en/e...module/hrLpQtE https://www.newtis.info/tisv2/a/en/e92-325i-cou/RX8xesi Please let us know what you find, George |
03-14-2020, 02:20 PM | #8 | |
Rep 32
I will purchase a multimeter this week and get back to you with my findings. Once again thanks for all of this information fingers crossed i can get this sorted soon. |
03-15-2020, 12:36 PM | #9 |
Rep 32
Pulled the CAS relay out and it was real hot, going to get a replacement to see if this changes anything. Tried grounding from the engine bay to the block with no luck.
03-15-2020, 01:26 PM | #10 | ||
2697
Rep 4,031
https://www.newtis.info/tisv2/a/en/e...cou/1VnYuo3ZrW When you post back with further information from testing, please provide build Month/Year of your 2007 model so we can provide/ reference correct circuit information. George |
03-15-2020, 03:19 PM | #11 |
Rep 32
Thanks George, its starting to pickle my head a bit!
It sounds like one click from the starter solenoid. Yes its Terminal 30G Relay as you described was quite hot when removing. Manufacture date is 05/2007 (May 2007). Jake. |
03-17-2020, 11:37 AM | #12 |
Rep 32
Can anyone confirm this is the replacement 30G Relay?
https://www.eurocarparts.com/p/bosch-relay-451110040 |
03-17-2020, 02:51 PM | #14 | |||
2697
Rep 4,031
61366901469 is the correct 11-digit BMW part# for IO1068, the Terminal 30G Relay or Accessory relay which has NOTHING to do with Starter operation. Rather than take a random opinion from someone who may not know what he is talking about, one should learn how to use RealOEM.com as a "Parts Catalog" to determine what is the correct part for his vehicle, with the location and the function of that part: https://www.realoem.com/bmw/enUS/par...469&series=E92 If you refer to the TIS circuit for the CAS Module that I linked in Post #7 of this thread: https://www.newtis.info/tisv2/a/en/e...system/uNYjfvY you will see that IO1068, Terminal 30G Relay is activated by the CAS Module. This happens when you press START (without foot on brake or Clutch) to Activate Ignition (Terminal 15) or IO1069 which is found next to IO1068 on the Schematic. The function and temperature of that IO1068 Relay is INDEPENDENT of whether the engine is running, or whether you attempt to activate the Starter. If the Starter does NOT crank the engine when you have an auxiliary ground cable between the chassis & engine, then as described near the end of post #7, I would suggest checking for 12V+ at Pin #1 of X6011. If NO voltage when START is pressed with Clutch Pedal Pressed, test Clutch Switch per description at end of that post. As for your question about the Orange Bosch Relay with UNIDENTIFIED "Product Code", you would have to ask EuroCarParts, as entering "BMW 61366901469" in their search box returns "NOT Found". Doing the same on AmazonUK site returns this page with correct part#: https://www.amazon.co.uk/s?k=bmw+613...ref=nb_sb_noss Please let us know what you find, George |
03-18-2020, 11:36 AM | #15 |
Rep 32
okay so i managed to get a copy of INPA that is actually working. anychance i can run a diagnostic to see whats working? like the clutch pedal sensor?
03-18-2020, 02:06 PM | #17 |
Rep 32
Okay quick update, i pulled eveything out and took the starter motor off again.
Hooked it up to a battery and it fires up and is working fine, its sliding back and spinning like it should so the Starter Motor is fully functional. |
03-18-2020, 02:11 PM | #18 | |
2697
Rep 4,031
1) CAS F5, F1, F2 Status Terminal Control; Digital, circles fill when active: Brake, P/N, Clutch, Engine, Vehicle Speed, Handbrake; KL30G; KL50(?) 2) F5, F2, F1 Diagnose Terminals (Klemmen); Analog Bar Graphs & Voltage Values: Shows Voltage at various Terminals including: R(Radio), 15(Ignition), 30G(Accessory), 50 (Only when START pressed) 3) F5, F4, F1 CAN Signals (Determine if Start Conditions Met -- AT Vehicle): Transmisson Gear (must be P/N) Contact (Switch) Brake Pedal (must be pressed) Status Engine Running (NOT already running) 4) F5, F4, F2 Terminal Signals (Signale Klemmen); Digital On/Off: Status Terminal (Klemme) 50: Off (Aus)/On (Ein) [3rd Row] Also shows status of Terminals R & 15, Ein/Aus = On/Off These screens are for my N52KP with GM6 AT, so your MT version should have clutch switch input in place of Gear Selected (P/N) where applicable. You may actually get better concepts of what the "Labels" or Descriptions for the data are by doing your own German to English translations. For purposes of these screens: Voltage = Spannung Clutch = Kupplung Terminal = Klemmen (NOT clamp ;-) "Terminal 50" or KL50 should have Voltage when Starter is Active or START pressed with foot on Brake (AT) or Clutch (MT) Brake = Bremse should be active (digital circle fills) if CAS receiving input from brake light switch. SAME for Clutch = Kupplung. If Brake or Clutch signal NOT received by CAS (and circle filled while pressed) then CAS will NOT provide activation of Terminal 50 (Start signal to Starter Solenoid). INPA makes diagnostics easy IF you know what it can show you, and you understand how the system at issue works (here the CAS circuit diagram from TIS). Please let us know what you find, or if any questions, George |
03-18-2020, 02:31 PM | #19 |
Rep 32
Thanks George, no i have ruled out it is not the starter motor i will move on to what you said for the next step. It wont be until tomorrow as i need to bolt everything back onto the car before i crank it, unless i can just try without the intake manifold on?
03-18-2020, 05:02 PM | #20 | |
2697
Rep 4,031
While you have the Intake Manifold off, and BEFORE you connect the wire from CAS to the Starter Solenoid, you can always just test for 12V+ at that wire (DISconnected from Starter Solenoid) when START is pressed with Clutch Pedal pressed, but INPA Screens 1 & 2 in previous post will tell the story. I would NOT press START before reassembly EXCEPT to test the disconnected Starter Solenoid CAS Start Signal wire for voltage as described above. The wire is the single wire at Connector X6510 shown in this photo: https://www.newtis.info/tisv2/a/en/e92-325i-cou/SCA14zi INPA Screens 1 & 2: 1) Input from Clutch Switch to CAS, causing circle to fill when Clutch Pedal pressed? 2) KL50 Voltage goes from 0 to ~ 10V (voltage drop expected) when START pressed if Clutch signal & CAS are OK. Try BOTH of those & let us know your findings. Since you have the Intake off, you might do each of the following to ensure you don't have to go back in there: A) Examine the wire that goes to the Solenoid for any possible damage; B) Test that wire electrically for continuity between X6510 and Pin #1 of X6011 in the E-box, per this diagram: https://www.newtis.info/tisv2/a/en/e92-325i-cou/SL92ADs George |
03-18-2020, 05:47 PM | #21 |
2440
Rep 4,330
as long as you don't push the brake pedal the car will not attempt to start.
OP should buy george a beer. the man is more patient than anyone I've ever seen on a forum. |
03-18-2020, 06:59 PM | #22 | |
2697
Rep 4,031
"NS", if you can figure out the Clutch Switch circuit, and how to test it, please let us know, as my SWAG is THAT is what is causing OP's "No-Crank. Thanks, George |
