BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Disable bi-xenon
      03-11-2020, 07:15 PM   #1
colorado.e9x
eBay Special
colorado.e9x's Avatar
3066
Drives: E90 330xi
2007 BMW 328xi  [9.50]
2006 BMW 330xi  [10.00]
Disable bi-xenon
I can't seem to find anywhere how to disable bi xenon on my FRM2, the shutter from the xenon is nowhere near as bright as the inner 'flash to pass' bulbs.
Can't seem to figure it out
Common sense is a flower that does not bloom in everyone's garden
      03-11-2020, 07:25 PM   #2
Vulcan50
Vulcan50's Avatar
433
Drives: e92 335i
Flash to pass should be the same function as high. Isn't it just one shield (per side) that moves out of the way. Probably an illusion from sudden change in output.
      03-12-2020, 01:17 AM   #3
colorado.e9x
eBay Special
3066
Drives: E90 330xi
Mine are aftermarket, the inner bulb throws more light than the xenon high beams (shutter)
      03-12-2020, 07:12 AM   #4
neilvan
neilvan's Avatar
858
Drives: 09 E90 335i M-Sport 6MT RWD
Why not run both? for full high beam and flash to pass? MAX POWERRRRRR
      03-12-2020, 08:30 AM   #5
ryan stewart
2197
Drives: 2008 328it
Im pretty sure in mine its the inner beam for flash and HID for full beam because the color temps are obviously different.
As far as brightness I wouldn't say the flash to pass is brighter. It does seem to cast down the center differently but the regular high beam does a much better job of illuminating everything but the center, lighting signs and deer hiding in the bushes, etc.
I wouldn't think disabling for the center beam it is going to make it any safer.
Brandoch461.50
      03-12-2020, 11:53 AM   #6
colorado.e9x
eBay Special
3066
Drives: E90 330xi
lmaooo yes I wish there was a way to run them at the same time
      03-12-2020, 11:54 AM   #7
colorado.e9x
eBay Special
3066
Drives: E90 330xi
Gotta remember my headlights are aftermarket. I'll see if I can make a video showing the difference when I get off work tonight. I'll let you be the judge
      03-12-2020, 12:08 PM   #8
lookalikehuuh
700
Drives: 2006 330i, 2007 335i
I'm totally interested in the video because my HID high beams are way brighter than my halogen ones. Even though i bought the supposed brightest Sylvania ultrastar or whatever they are called for the "high" beams
      03-12-2020, 01:48 PM   #9
e90yyc
Art Collector
e90yyc's Avatar
2425
Drives: 2007 328xi (GM-delete 6MT)
This must be possible. I have a pre-LCI (FRM 1) where pulling the stalk (flash-to-pass) is the halogen bulbs, not the bi-xenons.
I had it coded at one point to use the xenon's for flash-to-pass, but went back because unless they were already ignited, pulling the stalk would only move the shutter... I was probably missing some values that I needed, but it wasn't that important to me so I left it.
I'm not sure if FRM2 presents a different challenge here. If not, coding it should be straightforward. (I can check what I changed for you if you'd like.)
When I'm dead, just throw me in the trash.
      03-12-2020, 02:43 PM   #10
Andystobbs
191
Drives: E91 Lci, Vectra B V6
Can you not add a relay to achieve this?
      03-12-2020, 02:55 PM   #11
colorado.e9x
eBay Special
3066
Drives: E90 330xi
I know FRM1 was able to do it, I was able to code the inner halogens to be my high beams (and flash to pass) until I switched over to FRM2. I've since lost those coding options
      03-12-2020, 02:56 PM   #12
colorado.e9x
eBay Special
3066
Drives: E90 330xi
I didn't think about that. I'm mainly trying to achieve this by coding. I'm considering that route as a last resort
      03-12-2020, 02:57 PM   #13
colorado.e9x
eBay Special
3066
Drives: E90 330xi
I'll try to remember to take one and upload it tonight. The difference is substantial imo
Edit: After Clammy's fix, Im admittedly too lazy to code it back and make a video. Once again my headlights are aftermarket and were designed with both a shutter (to pair with cheap projectors) as well as a dedicated halogen high beam light. The halogens throw light much further, while the xenon's shutter spreads light to the sides more. Now with Clammy's fix, I have the best of both worlds!
      03-12-2020, 04:58 PM   #14
Clammy
322
Drives: 2006 330i 6MT
I coded my '06 330i to do exactly that.
In the NFRM, find the label PWM_FL_BEI_BIXENON and change both values to wert_01
This gives you the inner halogens, as well as the xenon high beams (shield lifted). It also maintains the inner halogens flash to pass function.
Cheers!
      03-12-2020, 06:22 PM   #15
e90yyc
Art Collector
e90yyc's Avatar
2425
Cheers!
Stupid question but this is on FRM1, yes? Judging by MY of your car I assume so, but thought I’d ask
      03-12-2020, 06:38 PM   #16
Clammy
322
Actually, I upgraded to an NFRM (FRM2), for some other options I wanted to enable. I'm not sure if this is possible with an FRM1.
Cheers!
      03-12-2020, 06:40 PM   #17
e90yyc
Art Collector
e90yyc's Avatar
2425
Actually, I upgraded to a NFRM (FRM2), for some other options I wanted to enable. I'm not sure if this is possible with an FRM1.
Cheers!
Ah! That would explain the absence of this option for me. Thanks for the info!
      03-12-2020, 07:05 PM   #18
Clammy
322
Happy to help.
I would highly recommend upgrading to the NFRM. You can find used ones super cheap on Ebay (I did), and then just use WinKFP to code the VIN (I'm not even sure this is required to get it to work, but it's easy, and did it just to be safe), and away you go with NCS Expert.
Cheers!
e90yyc2425.00
      03-12-2020, 08:15 PM   #19
colorado.e9x
eBay Special
3066
Drives: E90 330xi
Cheers!
Worked like a charm! Thanks! Mine was set to wert_03
      03-12-2020, 08:33 PM   #20
Clammy
322
Happy to help out. I've gotten SO much help from this forum, that it makes me happy to be able to give back, now and then!
Yeah, I think mine were wert_02 and wert_03. I'd found a document that said to change just wert_02 to wert_01. That did nothing. On nothing but a hunch, I tried changing them both, and BLAMMO! It worked perfectly!
Cheers!
      03-12-2020, 08:39 PM   #21
colorado.e9x
eBay Special
3066
Drives: E90 330xi
Cheers!
That's how I feel as well! But in reverse haha. Interestingly enough I only had to change one as the other didn't exist. It could be because I disabled the adaptive feature.
Hoping this post is useful to someone down the road who might experience the same problem
Cheers!
Clammy321.50
      03-12-2020, 08:46 PM   #22
Clammy
322
Cheers!
Ah, that makes sense. I have AHL, and they're enabled. Hence the 2 values! Nice! I've learned yet ANOTHER new thing about my car. Thanks.
Cheers!
