E92 335i light steering feel ? Help Please!
03-10-2020, 01:10 PM | #1 |
55
Rep 521
Hello all , I'm having trouble fixing a problem on my FBO 335i . Let me give you some background . When I first bought the car little over 2 years ago I was in love with the cars steering it was tight responsive and very sharp , especially around tight turns at speed, the car then was completely stock and on Michelin pilot super sports . Since then I'm now FBO and have an m3 away bar , lowered on Dinan springs, just recently bought brand new Michelin sport as3+ tires, and a 4 wheel Alignment. over the last 2 months the cars steering has felt super light , so light that I don't feel confident in taking turns as high of speed as I usually did before. Ive replaced the top strut hats when I threw the springs on , I've also replace both tie rods with Myle HD rods before the alignment . I also had my mechanic who is an Audi master tech who also owned an n54 , look at all control arm bushings and all suspension components before doing the alignment just to make sure everything checked out . I've search over the forms a bit and no one seems to have a light steering feel that I'm having so I'm sort of lost on what to do. I have noticed there are a couple of degrees of "slop" in the steering where you can turn the wheel a bit without the wheels moving , I know that has to do with the steering shaft but can that also be the cause of the loose steering all together ? It's just odd that I've done all this suspension work , and the steering wheel was 50 times tighter when I first threw in the m3 away bar (this was my first suspension mod on the car) . Please if anyone could shed some light I would appreciate it as the steering was my favorite part of the car ! Thank you in advance !
Also as a side note I have noticed that the steering decently tight when stopped (not as tight as before) but once you start moving the tightness disappears , the steering is still responsive (even with the small degree of slop) but is seriously light ! |
03-18-2020, 07:36 PM | #3 |
68
Rep 210
Sounds like the preload needs to be adjusted. I haven't done it yet so I'm not a ton of help but I have the same thing going on. Everything suspension/tie rod wise is good on my car but it's light and about 1/2" slop in the wheel. Some people have the bolt on the lower universal come loose on the steering collum but that isn't my case. I have an do so I can't get to the adjuster untill I drop my sub frame. I thing it's different on rwd tho. Not sure. I serched on duck duck go and found a few occurrences of the preload needing to be adjusted
335boston55.00 |
03-18-2020, 07:44 PM | #4 | |
55
Rep 521
03-19-2020, 02:32 AM | #5 |
84
Rep 256
Currently having the same issue with mine and it all started after I got an alignment at the dealer. Since then, I’ve done the m3 control arms, Meyle HD tie rods, new Endlinks and a new alignment and it feels much better but not nearly as sharp as it was before the dealer did the initial alignment.
2013 E92 M-Sport | Black Sapphire Metallic | Dinan S2 | M Performance exhaust | Wagner Evo 1 | Evolution Racewerks CP | Bilstein PSS9 | M3/Meyle HD/Dinan suspension bits | 18" AG M359, Michelin PSS
335boston55.00 |
03-19-2020, 01:41 PM | #7 | |
55
Rep 521
03-19-2020, 01:42 PM | #8 |
55
Rep 521
I found this post as well! It seems there is a e-12 screen that gets loose over time that can cause my exact symptoms . I'm going to try today to get to it and tighten to see if anything happens! https://www.e90post.com/forums/showt...125&page=2
03-20-2020, 02:38 PM | #9 |
55
Rep 521
Update : tighten the bolt in the post above , there's also a second bolt that connects at the top which I also tightened , steering felt slightly better but not what it used to be . I'm sort of leaning Towards the tires now, I did go from PSS to A/S 3+ (all seasons) and I knew there was going to be a slight decrease in handling but not this drastic . Before the steering was so amazingly tight and now it's lighter than my buds gti , driving me insane lol.
03-20-2020, 05:41 PM | #10 |
55
Rep 521
Another update , threw on my old rims / tires (PSS) and the the steering was heavier and more responsive but still have that play and was not at stiff as before I'm starting to suspect the steering shaft? Any input?
03-20-2020, 05:52 PM | #11 |
700
Rep 1,227
seems like the difference in tires is what is making the difference for you. Pilot Super Sports are much stickier than the all season AS3+ so you will lose some of that grip and confidence of course since you are gaining all weather performance and nearly double the mileage warranty.
03-20-2020, 05:54 PM | #12 | |
55
Rep 521
03-22-2020, 01:35 AM | #13 | |
700
Rep 1,227
Did the alignment shop give you print out on what the alignment specs were when they were done? |
335boston55.00 |
03-22-2020, 02:25 AM | #14 | ||
55
Rep 521
03-23-2020, 01:38 AM | #17 |
55
Rep 521
I did happen to check the fluid while this was all happening , looked clean and didn't even need to top off that much.
I'm suspecting this part is my issue: https://www.fcpeuro.com/products/bmw...ft-32306769157 Only thing is I can't find a DIY on it and I don't feel comfortable shelling out $380 on a part that I don't fully know will fix the issue . |
03-23-2020, 01:44 AM | #18 |
3058
Rep 3,910
It's easy to test that part; put your fingers at the telescopic joint, have someone wiggle the steering wheel (steering lock disengaged!), making sure they're applying torque one way then the other. If you can feel one part moving relative to the other, it's bad. If both parts move in unison, it's good.
My car has a solid tube there, rather than a telescopic part...not sure why. Maybe it's a Europe/UK thing. |
03-23-2020, 05:58 PM | #19 |
84
Rep 256
Quick update - I tightened the hell out of that bolt on the steering shaft and the car feels MUCH better. Cannot believe what a difference it made, honestly.
My advice: Turn the wheel clockwise so the screw is facing up, and give it all you got. I wouldn't say mine was loose before, but I managed to get another 1/2 turn and it really tightened up the steering response - especially at low speed, which is where I was having the most problems.
335boston55.00 |
03-24-2020, 01:29 AM | #20 | |
55
Rep 521
03-24-2020, 02:25 PM | #21 | |
84
Rep 256
Might need to order a wrench because as I was trying to get my ratchet in there, the bit fell off and into the the abyss. Anyone know what size wrench I would need? E10?
03-24-2020, 02:45 PM | #22 |
3058
Rep 3,910
E12, I think.
The end at the steering column will have some play, because the tip of the steering column isn't supported past the telescopic section of the column. |
