BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Driver's side mirror not working (aiming) via arrow pad
      03-09-2020, 01:32 PM   #1
speedeep
Drives: 2011 BMW 335d
I've read a bunch of threads having to do with E90 mirrors, but none that cover this exact issue (that I've found.)
2011 335d
* Mirror fuses are intact.
* Both mirrors fold correctly on door button press and vehicle lock/unlock (as coded)
* When the sliding mirror selector switch is set to the left (driver's side) using the arrow pad adjusts the passenger mirror.
* When the sliding mirror selector switch is to the right (passenger's side), using the arrow pad also adjusts the passenger mirror.
* Both mirrors respond to memory positions, both adjust correctly when switching between memory 1 & 2.
* When manually adjusted (pushing mirror to a position by hand, then setting memory) the mirror position is remembered and recalled correctly when the memory position is switched between memory 1 & 2.
The car has control of the mirrors, the mirrors seems to work for memory recall, but the driver's side mirror doesn't respond to input on the arrow pad. When the mirror selector switch is set to driver's side and arrow pad is used, passenger mirror adjusts. No input on the arrow pad affects the aiming of the driver's side mirror.
Any help appreciated.
Tags
e90, mirror
