F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > use ISTA remotely through VPN ?
GetBMWParts
      03-07-2020, 10:14 AM   #1
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
hi, did anyone figured out how to use ISTA through VPN network?
using esys without any problem, but can't get ISTA working remotely.
      03-07-2020, 12:21 PM   #2
cossie1
625
Drives: 2015 F82 M4
How do you use E-sys remotely via VPN ?
      03-07-2020, 01:49 PM   #3
RuleNormaliai
235
i use hamachi VPN and connect through IP. the pros are that remote pc does not have to have any files such as launchers, psdzdata files or even esys.. just Laptop with internet, Hamachi VPN and enet cable.
Appreciate 2
cossie1624.50
      07-14-2020, 09:00 AM   #4
john440022
Drives: F30 328i
would you teach me how to use VPN connects with E-SYS, please?
      04-07-2021, 01:34 PM   #5
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
it is possible to connect a remote car to ISTA with VPN
      07-05-2022, 01:41 AM   #6
youttiao
Drives: m3
Hi, I tried but failed, any trick settings? after vpn connection, just input the enet IP found in Client PC to the Host ISTA, and ISTA can read the vehicle?
      07-05-2022, 01:45 AM   #7
TheNine90
578
Drives: bmw
Easiest way it to use RemoteEnet by Esysx. Just activate it then start VPN ,I use team viewer
      07-05-2022, 02:46 AM   #8
youttiao
Drives: m3
remote connect esys is very easy, but I can get ista remotely working.
I saw the IP direct connection method in the connection option, add the vpn assigned address for the client computer but connection failed.
maybe need to set some route or iptable?
btw, any one know ista working port?icom mode or enet mode.
      07-05-2022, 03:05 AM   #9
RuleNormaliai
235
1. in ista choose to connect by ediabas
2. change ediabas IP: VPN IP, Interface: ENET, and PORT: 6801 (i use EDIABAS KONFIGURATOR 2.0.0 for that)
Success.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
      09-20-2022, 01:14 AM   #10
TheNine90
578
Drives: bmw
ISTA set to EDIABAS Connection. EasyConnect is set to ENET/REMOTE with correct Remote IP. PORT: 6801
      02-14-2023, 03:36 AM   #11
Juanth
Drives: BMW X5
My proxy connection is stable. I bought proxies here - https://proxys.io/en. You can test their work, everything should work.
      02-23-2023, 04:22 AM   #12
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by franssuing91 View Post
Have you found some solution to your problem? I can't do anything for the third day. Since the very beginning of September, I have been experiencing great difficulties with the Internet connecting to my computer. I have already checked everything possible, but this is a problem with my Internet provider. Previously, this would not have bothered me, but now I need good Internet at home to work. I use a brazil proxy for work, and for this service to work properly, I need to fix the problem with the Internet connection somehow, so I'm here. I hope someone will answer me and tell me what I can do in this case.
This service is what you need:
      02-25-2023, 07:49 PM   #13
AMcKinney94
Drives: 2017 330i xDrive
Where can I download ista+ ista/p? Anybody have a link?
f30post
