new to me '06 330i, only one key fob
03-05-2020, 02:57 PM | #1 |
Rep 32
purchased this '06 330i second hand and got a pretty decent deal on it.
only issue is that there is only one keyfob. I've read that sometimes a fuse can go out and disable the system until a new one is put in its place? i have to take the small key out and place in the door handle to lock and unlock my vehicle. Contacted the local BMW dealer, and they quoted me i believe $247.xx for a new replacement/programming etc. etc. this keyfob is i'm assuming an older style in that i cannot replace the battery. I do have soldering skills, and I can "attempt" to purchase a rechargeable battery and solder a new one in its place? anyone have any advice? or am i better off going to the dealer? |
03-05-2020, 03:03 PM | #2 |
858
Rep 1,363
Drives: 09 E90 335i M-Sport 6MT RWD
IMO Id get a second key cut/programmed and then Id try replacing the battery yourself(just incase shit goes south) and you want 2 keys anyways
MSBe902.00 Persian Whisperjet166.50 |
03-05-2020, 03:20 PM | #4 |
General
17315
Rep 18,737
The key for non-comfort access system has a rechargable battery in it. If you keep the key in the key slot it will recharge the key battery. A new key is a bit pricey, but best to source from the dealer to avoid programming hassles.
MSBe902.00 |
03-05-2020, 03:34 PM | #5 | |||
Rep 32
does anyone know if i can try a programming method or if there is a DIY solution to maybe try and see if the key will re-initialize? |
03-05-2020, 06:32 PM | #6 |
45
Rep 158
Drives: 2011 328i
That's a good price form the dealer, when I got a quote to replace a comfort access fob (which should be cheaper because no rechargeable battery) it was over $400.
03-05-2020, 06:56 PM | #7 |
1911
Rep 13,104
https://www.e90post.com/forums/showthread.php?t=1510527 Contact: +1.985.492.0666 call/text or email GcodingBMW AT Gmail.COM Facebook: www.facebook.com/GcodingBMW http://www.bimmerfest.com/forums/sho...d.php?t=903551 Read entry 13 and it's associated threads in the above link. The mashman chronicles. https://www.teacremotes.com/bmwgm5/ Last edited by ctuna; 03-05-2020 at 07:01 PM.. |
lab_rat394.50 |
03-06-2020, 08:15 PM | #9 |
1911
Rep 13,104
Thing is with only one working Fob when you loose you
are more or less at the mercy of the dealer or some hack keymaker that doesn't know what he's doing. |
03-08-2020, 12:34 AM | #10 |
Kind of a Big Deal
167
Rep 857
FYI if the issue is you are not holding a charge due to advanced battery age, I just soldered both of mine and my wife's two (both cars are E90s) and it was not bad at all. Agree it makes sense to wait until after you get a second FOB tho.
03-08-2020, 09:12 AM | #11 | |
Rep 32
From the videos I’ve seen, it seems that little spiral battery contact is the only thing that gets soldered |
03-08-2020, 09:26 PM | #12 |
Art Collector
2425
Rep 3,448
Agree with post above that the price you were quoted is shockingly reasonable, assuming it’s fob and key blade including all programming. I would personally go for that, and then as others have said, attempt to resuscitate your original fob.
Even if your fob worked, having just one key is risky. If you ever lose it or god forbid lock it inside (hard to do but possible), you’re entirely at the mercy of the dealer. They can smell it too, so that ~$250 quote will probably become $500 if you walk in there having lost your key
When I'm dead, just throw me in the trash.
03-10-2020, 09:13 AM | #13 |
General
17315
Rep 18,737
So interestingly, I've misplaced my regular key just after your Thread. Going to my back up key, which is rarely used. I try to use it occasionally to keep it charged. This week, I got the low key battery warning. I drive the car 4 hours a day at 2 ea. 2-hour stints at a time. I got low key battery warning at two times on Monday, but by last night when I parked, it did not throw a warning. This morning, after a 10-hour key rest, there was no warning, so I think the key is back to full charge. So just as a point of reference, 6 hours charged my key.
CDirks135.00 |
03-10-2020, 10:30 AM | #14 | |
Rep 32
i found a wireless charger at a store local to me for $20. |
03-11-2020, 09:11 AM | #15 |
78
Rep 244
Drives: 2006 330i Manual
I've actually had good luck getting a backup FOB from eBay for about $120. I had to send in the original FOB with my CAS and the seller boy had a one day turnaround. I timed it with my trip to DAB and PRG and it was ready when I got back home. The only thing that needs to be done is have the metal key cut.
03-11-2020, 12:50 PM | #17 | |
2001
Rep 3,731
Are there any other options to make the ebay keys work? I only have one key fob for my 07' 335i...and the dealer wants $320 to order a pre-programmed one in for me.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
03-11-2020, 09:41 PM | #18 | |
78
Rep 244
03-11-2020, 10:01 PM | #19 | |
2001
Rep 3,731
03-11-2020, 10:03 PM | #20 |
78
Rep 244
I messaged you.
