Any solutions to leaking oil filler cap?
03-04-2020, 12:31 AM | #1 |
55
Rep 521
Hello all! I've replaced my oil filler cap twice and it's still leaking . Stumbled on a new style oem cap that fcp says it will fit my car . Was wondering if this "new" design has a better seal than the original one or if there is any other better solution? I'll attach the link to the cap! Thanks in advance !
https://www.fcpeuro.com/products/bmw...ap-11127560482 |
03-04-2020, 04:22 PM | #3 | |
27
Rep 87
OP, how many oil caps are you going to replace until you realize that's not going to stop the leaking? |
03-06-2020, 10:52 AM | #5 |
55
Rep 521
03-06-2020, 10:53 AM | #6 | ||
55
Rep 521
03-06-2020, 06:39 PM | #7 |
648
Rep 2,012
I wanted to make something like this,
https://vargasturbo.com/product/vtt-...case-breather/
335i e92 TPC 19Ts
335boston55.00 |
03-09-2020, 11:32 AM | #8 | |
55
Rep 521
I looked into those a bit too , but some people complained and got worried about oil expelling out of that filter into the engine bay. Some people for some reason take the gasket out of the oem cap clean it with brake cleaner then reverse the gasket when installing and have no leaks I think I might try it before I buy another cap . |
03-09-2020, 11:44 AM | #10 |
55
Rep 521
03-09-2020, 12:09 PM | #12 |
2440
Rep 4,330
assuming it has a check valve in it to keep it from becoming a giant vacuum leak I see no reason why not.
but really if your engine is making that much crankcase pressure and it's not a big baller high boost turbo car you should probably find out why. |
03-09-2020, 12:13 PM | #13 |
2996
Rep 1,798
It was more of a curiosity.
I'm not about to rip out my existing system (though it would cut down on some fire hazards) it is working fine. There would be at least 3 hoses that would need to be capped off if I replaced it with this thingamajig. It certainly would simplify the whole external system the magnesium valve cover early N52s got. |
03-09-2020, 02:08 PM | #14 |
1903
Rep 6,968
