335d Intake Manifold Removal
02-29-2020, 09:57 PM | #1 |
Rep 13
I'm finally getting around to doing a carbon cleaning and am trying to remove the intake manifold with the least amount of pain. The only video I've found is this one, but he cut some cooler & vacuum lines and fully removed the EGR cooler:
That seems unnecessary just to get the manifold off. I'm stuck at the area where the EGR valve and throttle body are connected. I removed the "hose" clamp that connects the EGR cooler to the EGR valve, but do I need to actually loosen the EGR cooler from the engine body to separate them? Know I still need to remove the air intake hose from the throttle valve and unlock the clip holding the wire on top. Any other tips? TIA! Last edited by sjobs99; 02-29-2020 at 10:47 PM.. |
03-01-2020, 09:32 AM | #2 |
806
Rep 1,191
Disconnect the boost hose and move it over to the right. Look under the EGR valve, there's a 10mm bolt that needs to come out in order for the manifold to lift. No need to take the EGR cooler off, but it helps loosening it.
03-01-2020, 05:33 PM | #3 |
Rep 13
That did the trick and I didn't have to loosen the EGR cooler. Off to Harbor Freight for a media blaster!
03-02-2020, 11:06 AM | #4 |
Rep 13
Went to use the borescope I bought a couple of months ago and the problem I'm having is the camera has a tiny lip on the end, so every time I put it down the intake to view the valve position, it scrapes a side and gets covered with the black carbon goop.
Is there something I can use to clean as much of the carbon out so I can hopefully get a "clear" view of what's going on in there? I'm not going to pour anything in there, but was thinking I could moisten an old t-shirt with some solvent and stick it down there to clean it? Also, any estimate how far beyond the bend in the intake I need to get in order to view the valve position? |
03-02-2020, 03:25 PM | #5 | |
277
Rep 1,575
03-02-2020, 09:03 PM | #6 |
Rep 13
I'll give that a shot! I found a local place who said they'd put my intake manifold in their pressure washer. I know I need to remove the EGR & throttle valves and I'll take off all the gaskets, but is there anything else I need to uninstall/remove from the manifold before giving it to them?
03-16-2020, 08:18 PM | #8 | |
Rep 49
