02-29-2020, 01:46 PM | #1 |
Yiolli
26
Rep 119
I followed a DIY for installing a burger motor sport JB on my car and I just want to make sure that the plastic covering that goes over the wiper assembly in the driver side was installed properly.
It seems like there is a spot that is not completely sealed and I'm not sure if that would leave room for water to get in. Is this thing meant to waterproof? Could someone shed light on this? |
02-29-2020, 03:37 PM | #2 |
8245
Rep 16,088
Looks bent to me. It's easy to remove, just turn the hex head fasteners and it will lift right off. Once you get it off you'll see how the fasteners hold it down, and the nubs that the fasteners grab. That tells you what you need to know to put it back in place correctly. The last person to put it in place probably didn't fasten it correctly, then closed the hood, bending the trim.
02-29-2020, 03:59 PM | #3 | |
Yiolli
26
Rep 119
03-01-2020, 10:27 AM | #5 | |
Yiolli
26
Rep 119
I did install it and it looks a little more snug than the first pictures that I posted. Check out updated pictures. Thoughts ? There's definitely a small area completely airtight |
03-01-2020, 11:52 AM | #6 |
8245
Rep 16,088
Yours is a different shape from mine, so it's probably OK. You'll know if it's installed right if there's no bouncing of the trim when you press on it near the latches, and no lifting if you gently pull up on the section that looks like a viaduct.
Yiolli25.50 |
03-01-2020, 02:55 PM | #7 |
Yiolli
26
Rep 119
It does seem tightly secure it's just the little space that isn't sealed.
Anyone else with an n20 that has a plastic covering not completely sealed like mine is? |
03-01-2020, 09:46 PM | #8 |
8245
Rep 16,088
I wouldn't be concerned about it not being sealed, water is supposed to get under it anyway. There are drains in the sheet metal below it. The main purpose of the trim is to keep other stuff, like leaves, out so they won't clog the drains. I find that leaves still manage to get under there, so I pull the trim off every six months or so and blow the accumulated crap out with a leaf blower.
Yiolli25.50 |
03-02-2020, 10:45 AM | #9 | |
Yiolli
26
Rep 119
But thanks, the water was my main concern. |
