02-28-2020, 03:09 PM | #1 |
Rep 11
I need help with my coding LDW
Hello
I did retrofit my steering wheel with the vibrator, new cable, and module to be able to use LDW. I installed the buttons console as well 32336787451 vibrator 61319218381 module 32306854771 extended cable 61319268479 buttons console 51459239299 new console molding My current SZL 61319351145 (small slot 4 pins, is not wired) but this slot is only for switch heated I followed the FLC coding in bimerfest this and I coded with e-sys all parameters When I start the car, I and touch the boton and the two yellow lanes appears, but few seconds after, de LDW is desactivated and does not work. a msg n HUD and KOMBI appears saying not working SLW I checked with ISTA and have this msg 030351 K-LIN 16 sterring column switch cluster (SZL): wrong version 030490 Steering wheel electronics module (LRE): Missing LIN slave I read similar topics about Heated Steering retrofit, but in my case I not going to use this, so this msg are related this SZL. I read as well that SZL need to be recoded, but i'm not sure if not changing the szl like me, but adding new functionalities, I will need to recode.... and how to do (E-sys.. ISTA P) Can someone help me ? Last edited by kaciker; 03-02-2020 at 08:33 AM.. |
