The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > BMW 335D Turbo removal
      02-24-2020, 09:37 AM   #1
Boyd122
Drives: Bmw 335D bmw 325es 1986
Post BMW 335D Turbo removal
Having to pull my turbos on my 335d due to bad seals, will be upgrading the blades on them, however before I start how do I remove them? I work on big diesels such as C-15 Cat engines and pickups but never a BMW and was wondering if I need to remove the Valve cover again and such things or if i can remove it without doing this..
      02-24-2020, 02:02 PM   #2
RL18
274
Drives: 2011 335d sport
I've never seen any DIY for this. Things that come to mind though is intake manifold should be off, intercooler disconnected, vacuum box removed, intake piping disconnected, downpipe disconnected, if you have emissions on still the egr will need to be disconnected, oil lines will need to be disconnected from the block, from there I'd think it would be pretty straightforward... Then I'm thinking you remove the HP turbo from the manifold and the piping going to the LP turbo first, then from there you can probably get at all the bolts to remove the manifold and pull out the LP turbo.
I've never done it though so there could be other ways, but that's how I would approach it if I were to do it.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      02-24-2020, 02:23 PM   #3
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
Here you go. https://www.newtis.info/tisv2/a/en/e...-with-control/
Appreciate 2
RL18273.50
      02-24-2020, 09:43 PM   #4
Boyd122
Originally Posted by smass View Post
Thank you both so much, I have a All data but forgot the password for the account sadly, seems to be a easy task! Thank y'all!
Also does anyone know if Tims Turbo stage two for the 335d is two much for the engine to handle for daily driving? I'm considering exchanging for stage two or one but wanted to see what the turnout if any is for someone who has them already... or just a horsepower rating on them that's known.
https://www.timsturbos.com/performance-vehicles/bmw/
      02-25-2020, 07:29 AM   #5
RL18
274
The reliability is all in how you drive it and having a good tuner to tune it. I can hook you up with my tuner BRR if you'd like he has a great hybrid turbo option. I'll be going with him when my turbos on my 335d or x5d decide to die on me. You should be able to safely get 450whp with the stage 2 option though.
M5_1of400229.50
      02-25-2020, 08:01 AM   #6
Boyd122
Post
I Maintain the car pretty well, the previous owner didn't which explains why the turbo seals have failed I drive 14 miles everyday to work and back, however I don't like dogging my vehicles, however on some days I will drive fast or get on the throttle but those are days that I'm free on. Anyyyywayyyy I will get on getting my turbo's out so I can get it running again...
RL18273.50
      02-26-2020, 08:02 AM   #7
Boyd122
[IMG]
[/IMG]
This is my high pressure and it ate the seals in the low pressure as well as the fan blades.
      02-27-2020, 11:17 PM   #8
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Small turbo from above. No VC needs to come off.
Large turbo from underneath and back. Need to remove DPF/downpipe. Replace main oil feed line while at it.
      02-27-2020, 11:20 PM   #9
Boyd122
I removed it without taking the VCG off, plus I re did the VCG 100 miles before the turbo took a dump, everything it getting rebuild as we speak, everything is getting replaced and the car is deleted completely of emissions lol
