Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > urgent - stranded - loss of power
      02-22-2020, 10:38 AM   #1
spurcap
Drives: 2006 330i 2012 x5 35d
hi
I am stranded out of town right now. this morning had no codes and no issues, now all of a sudden had engine malfunction power reduced error and have about 7 codes. hope it's something easy so I can get home but all garages are closed. if I can't fix I'm in a hotel util monday. attached carly screen shot. 2012 x5d with 113,000 miles
      02-22-2020, 01:02 PM   #2
Tambohamilton
3058
Drives: E91 330d
From that, I'm reading that your EGR valve is stuck, and there's a problem with your adblue system. There may also be an issue with your MAF, but the chances are it's just reading incorrectly due to incorrect EGR flow.
Personally I'd just clear the codes and drive. If it happens again quickly, maybe disconnect the MAF to see if it'll run better without it.
You might want to repost this in the general section just to get a bit more traffic.... More chance you'll get home!
      02-22-2020, 02:57 PM   #3
Mik325tds
Mik325tds's Avatar
806
Drives: 335d M-Sport
Post where you are stranded. Maybe some member close by can help. If you're around Detroit I'd help.
      02-22-2020, 04:56 PM   #4
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
+1 on this. If the EGR is stuck you can remove the plastic cover on the side to manually move it closed. Then clear codes, unplug MAF and drive home. Unplugging MAF disables EGR. I drove around like this a lot when I was troubleshooting EGR issues.
      02-22-2020, 05:29 PM   #5
Tambohamilton
3058
Drives: E91 330d
Nice, that's a good little hack; MAF unplug disabling EGR.
I also forgot you can move the EGR manually by removing the cover on the valve...
Good knowledge.
OP, can you try this and see how you get on?
