Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > what is the source of oil leaking?
      02-17-2020, 12:29 PM   #1
mhd
Drives: 2009 335D, 1989 325iC
Hi mighty Diesel 3ers,
After I took off the engine air filter box and it's hose in the engine bay, I found a puddle of oil inside the seal of the air intake hose. The oil was found in part 7 of the following diagram
The hose seems for clean air and the oil should now show here at all.
Can anyone know where the source of this oil leaking?
The oil leaking (circled region) is shown in the following photo:
Thanks in advance.
Last edited by mhd; 02-17-2020 at 01:54 PM.. Reason: add a new picture to clarification
      02-17-2020, 08:54 PM   #2
Xerix
30
Drives: 2010 335d
This is the oil condensing from the CCV in your Air Intake. Part # 5 in the diagram is what connects the intake to the Crank Case Ventilator (CCV). Only thing you can do is put an oil separator on or replace the seal at part # 7 and hope it doesn't leak as much.
      02-18-2020, 07:42 AM   #3
mhd
Yes, you are right!
I can see the trail of oil inside the connection hose (part #5). Thanks for pointing out the source so that I can do more research on both your suggestions.
