HELP please! How to store car for 6 months
09-07-2008, 06:56 PM | #1 |
Rep 2
Hi,
Im planning to keep my BMW 335 in the garage for winter and im wondering if there was anything i should do or not do. any advice would help thank you! |
09-07-2008, 11:03 PM | #2 |
15
Rep 367
keep a battery tender on it to keep the battery healthy.
You can pick one up at the dealer for less than $100 i believe
08 Z4 3.0SI Black Sapphire/Black Int, 6sp, Sport/Premium --- retired --- 2010 BMW 650GS -- Z4 replacement Working with the most talented people on the most technically advanced automobiles.... |
09-08-2008, 12:25 AM | #3 |
3189
Rep 10,509
store it just like a motorcycle... oil change, full tank of fuel with fuel stabilizer (make sure you run the motor for ~5min so the the stabilizer gets into all of the fuel lines and injectors), battery tender on the battery, cover it with a high quality breathable car cover
Also, for what its worth, even though I did all of the above to my motorcycle I would take it out and ride it (bringing the engine oil up to full operating temperature) whenever the temps were over 36F and the ground was dry/free of salt. (I would refill the fuel tank and add the appropriate amount of fuel stabilizer after each ride) You avoid a LOT of potential issues if you keep the vehicle moving whenever possible throughout the winter The first winter I had my bike I left it in storage for the full winter, and in the spring I found that the tires were slightly flat spotted, the carbs needed adjustment, and it was hard to start the first couple of times. Each winter after I ran the bike whenever possible and didn't have any storage related issues Oh, and lastly, make sure you store the car on concrete.. if you store the car over grass/soil/dirt the condensation from underneath will cause a lot of corrosion |
09-08-2008, 12:39 AM | #4 |
Rep 117
Definitely a battery charger/maintainer. I've used one from Sears for a few years now and it works great. It only cost about $30(model #71220 or 71219). Also, putting the car on jack stands will take the weight off of the tires to prevent flat spots. Put some STA-BIL fuel stabilizer in to keep your gas from breaking down. It would be good to start the engine once a week as well and if possible take it for a drive.
09-08-2008, 02:39 PM | #6 |
424
Rep 4,709
