02-05-2020, 05:42 PM | #1 |
658
Rep 1,479
Drives: 2020 M340Xi (G20)
Rim Protectors
Hi,
I hate to say it, but with the cr***y weather of late, we have gotten rim rash on 2 wheels of 20 M340 with 791M wheels. I know, I know should be careful & use side view mirrors, BUT as the saying goes, "Kaka occurs!" In that case does anyone have any recommendations on some good rim protectors? Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
04-28-2020, 04:03 PM | #2 |
45
Rep 243
Did you find any?
I did the same on one of mine. Never done it on a car before. I think the wheel/tyre combination coming from the factory is one where the tyre is not proud of the wheel enough to protect it, or maybe because the tyres are such a low profile brings the wheel down low enough to catch the curb. Or both those things. |
04-29-2020, 07:05 AM | #3 |
927
Rep 1,496
Did you just censor the word "crappy"?
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i | |
04-29-2020, 08:44 AM | #4 |
658
Rep 1,479
@hottroc ,
Unfortunately, I haven't I checked with Rim Blades, but as they told me they won't work on my wheels because of the small gaps in rim where spokes connect (M791 wheels). Since I had a bad experience with my F30 with rim Protectors (bought from a reputable place, followed installation guidelines, let cure, but came off in a week or less), I've been cautious. I used extra fine wheel on my Dremel tool & 1500 sandpaper to buff out dings (see my post on another thread) & had them re-created with ceramic Having said that, am still looking for rim Protectors
Al
04-30-2020, 05:40 AM | #5 |
45
Rep 243
I believe I have the same wheels as you. They are lovely wheels.
I've sanded out my rash but it has left the allloy area concerned a little dull. I could just coat with polish and/or ceramic but I was wondering if the wheels initially had a top-coat of clear lacquer? If so I'd do that first. If you do manage to find rim-protectors drop me a PM as I too can see this happening again. The wheels are low-profile so line up with the curb and the tyres not fat enough to protect. I have the run-flats, maybe that's why there's no bulge in the tyre like a normal tyre. |
04-30-2020, 06:45 AM | #6 | |
Grumpy Old Git
443
Rep 923
Drives: BMW G20 330i RWD M Sport
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R |
04-30-2020, 06:53 AM | #7 |
45
Rep 243
Thanks.
So my plan is to polish with Brasso, then apply a top coat or two (I have a touch up stick of clear lacquer rather than spray but think it will do), then a coat of proper polish (and ceramic eventually). Does that sound right? |
04-30-2020, 09:30 AM | #8 |
Grumpy Old Git
443
Rep 923
Sounds right although I would make sure you get any oil residue off after using brasso and before you apply the clear lacquer.
Retired:
04-30-2020, 10:01 AM | #10 |
Grumpy Old Git
443
Rep 923
Yes, that would do it.
Before you do it use as fine a wet and dry sandpaper you can get 2500 or greater will help give it a really smooth surface and better shine of the dull surface.
Retired:
04-30-2020, 10:14 AM | #11 | |
658
Rep 1,479
I agree with @Tam the Bam! After using my Dremel tool with 400 grit wheel, I then used 1500 & finally 3000 grit sandpaper. You can then use something like Brasso and wipe with Isoprpyl Alcohol (at least 71%) before clear coating. Will do on sending you PM if I find Rim Protectros; please do the same Thanks
Al
04-30-2020, 12:03 PM | #12 |
45
Rep 243
Thanks guys. 1500 grade is the finest I've got at the moment but I'll see if I can get out to Halfrauds to get some 3000.
Another query, are all clear lacquers the same? Think the one I have is a Nissan one, presume it will do? |
04-30-2020, 12:35 PM | #13 |
Grumpy Old Git
443
Rep 923
Don’t see why not.... try it on something first?
Retired:
04-30-2020, 06:06 PM | #14 |
5210
Rep 3,929
What's a rim protector?
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
05-01-2020, 04:02 AM | #15 |
Grumpy Old Git
443
Rep 923
Retired:
Burrcold5210.00 |
05-01-2020, 04:48 AM | #16 |
45
Rep 243
Hmm, don't think Halfords sell 3000 grade, might have to search on ebay.
05-01-2020, 05:48 AM | #17 |
Grumpy Old Git
443
Rep 923
I got a pack of different grades on eBay.
Retired:
05-07-2020, 10:30 AM | #18 |
45
Rep 243
Having looked at the wheels again, they are not ultra-shiny like chrome, it's more of a slightly brushed effect. So I'm thinking the higher grade sandpapers might not be a good idea.
Any tips on how to get that effect? They are totally smooth but looks more like a semi-polished aluminium, I'm wondering if it should be left a little rougher then smoothed with the top coat? |
05-07-2020, 10:38 AM | #19 | |
Grumpy Old Git
443
Rep 923
Retired:
05-07-2020, 10:45 AM | #20 |
45
Rep 243
Thanks for your advice, I'll have to try with a different grade.
The rim looks finer than the spokes. I was only supposed to be repairing the rim but caught a couple of spokes a few times with the sandpaper which has taken the shine off. The brushed effect is more prominent on the spokes but I don't want to risk sanding them much more, I'll end up having to do the whole wheel, then the other 3 to match lol. |
05-07-2020, 11:24 AM | #21 | |
Grumpy Old Git
443
Rep 923
Retired:
RSnic657.50 |
