Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Reliability of 100k mile 335d as a daily.
      02-01-2020, 11:08 AM   #1
Kbturbo01
Drives: 2010 335d
Back in 2014 I bought a 2010 335d with 25k miles still under warranty. I absolutely loved that car but unfortunately only had it a year. I’m looking for a new daily and am seeing some 11’s pop up with 100k miles for $6-$9k. I remember how fun that car was to drive. My concern with one that has higher mileage is the maintenance or repair costs I might run into because of the mileage. I’m looking for some advice from you guys. What to look for? What to shy away from. I’m a classic car and performance tech by trade so I would hope I can do most if not all of the repairs. My 2010 was one of the top cars I’ve ever owned as far as enjoyment. I’m just afraid to buy a car for $6k and it cost me a few more thousand dollars to repair a short time later. Thanks for any and all advice and opinions.
      02-01-2020, 09:16 PM   #2
9mmkungfu
198
Drives: 335d, 535d, 750i, X5 35d
Common failure items:
Thermostat
Glow plug module
Injectors
Harmonic balancer/crank pulley
Vacuum lines
RDC module
SCR system
If these have all been recently replaced, you'll probably be fine for a long time to come.
This is coming from someone who bought a 2010 w/ 111k miles back in 2014, and am now at 195k.
      02-01-2020, 11:35 PM   #3
PURE340i
104
Drives: 2018 BMW 340i & 2011 335d
I just hit 189k miles.... still runs like a champ! My DEF tank needs to be replaced and I just got one, but haven't replaced it yet.
      02-02-2020, 02:49 AM   #4
RED-d
27
Drives: 2010 335d Sport, Tuned
By far the biggest issue with these cars are the emission systems. You should move forward with the thought of deleting yourself or getting one already deleted. If I was in your shoes I'd buy one already deleted and tuned from an enthusiast. Much cheaper than paying retail for everything. Even if you do your own labor. As a bonus, most of the items listed by 9mmkungfu might have already be taken care of.
      02-02-2020, 03:03 AM   #5
cozzyman
12
Drives: BMW 335d AUDI RS6 AVANT
I'm at 168,000mls on mine, 380bhp TC performance map egr delete, dpf delete, 6 speed manual conversion. runs sweet as a nut, zero issues in 3yrs.
Appreciate 2
      02-02-2020, 08:25 AM   #6
Kbturbo01
Drives: 2010 335d
Thanks guys. The problem i am seeing with the cheaper ones in my area is they are at these small used dealerships who probably picked them up at an auction and have no service records. From what I’m reading, I should be prepared to invest some money when I purchase.
      02-02-2020, 10:57 AM   #7
9mmkungfu
198
Service records would certainly be helpful. BMW has also extended the warranty on several items now (SCR, FRM) but I believe they were only to 10 years / 100k, which the cars will be aging out of soon, if not already.
      02-02-2020, 07:13 PM   #8
apexit4
Poland
1231
Drives: 335D M-Sport, X5D
For clarification, it's 10 years or 120k miles (NOx sensors included)
      02-03-2020, 12:07 AM   #9
CokeZeroRocks
Drives: Maybe 335D
That's going to be the case for almost all of them. They're getting to long in tooth for bmw dealerships to take on and may be harder to move privately than 335i. I just picked up a 2011 from a small dealer local to me. The car was locally owned and maintained at local bmw, and according to car fax had just 2 owners. If I see 4-5 owners, that to me indicates the vehicle may have some issues.
      02-03-2020, 08:32 AM   #10
Spyro235
260
Drives: '10 X5D, '04 330i ZHP
I see you're in florida. Deletes are possible there, so if you budget to assume you'll need deletes at some point in the next 50-70k, then I see no issue she wont keep thrummin along.
I bought my X5d at 203k miles and I'm about to roll over 250k. If it's current on maintenance, then you shouldnt have any major issues anytime soon.
Daily/ Tow: 2010 X5 35D - 326k, Deleted w/DUDMD Stage 2, Sutphin Trans tune, Comfort seat retrofit
Fun car: 2004 ZHP 6mt - 256k miles, z4m FCAB, stock. Drift car: 2001 330i for sale
      02-09-2020, 12:50 PM   #11
cm335d
59
Drives: 2011 BMW 335d
Be aware that anything made out of rubber will start failing around 100k (if not before). Suspension (control arm bushings), window seals, door seals, vacuum lines, harmonic balancer, motor mounts, turbo solenoids (pain in the ass to replace btw), trunk handle rubber covering... anything rubber. BMW did a shitty job specifying Likely more natural rubber content that just doesn’t last. Also be aware of connectors in the e-box that can and will give intermittent faults if dirty, slightly loose, or just plain don’t like you, lol.
I have a love/hate for my 2011. Bought it at 51k, and now have 135k 5Yrs later. It’s the true unicorn car. Great power, great fuel mileage, good handling, fits a family of 4...however, it’s a high maintenance bitch that will require time, money, and patience as you accumulate miles. More than any car I’ve ever owned.
Hope that helps.
      02-11-2020, 03:11 AM   #12
crowbarsteel
Drives: Ram 1500 ecodiesel, BMW 335d
Bought mine with 97k last July. In 6k miles I have done the vacuum lines, full deletes, tune, trans tune, full trans service with mechatronics seals, rear diff fluid, oil change, thermostat with new coolant and am about to replace all the dampers with mounts/bushings, front M3 control arms, diff bushings and rear subframe bushings. I love the car but you gotta pay to play with the higher miles. Maintenance will likely need caught up and then repairs will need done due to wear from 100k. That being said, I love it. BRR tuned to about 360whp (vdynos no real dyno) with gobs of torque and 40+mpg to boot. It really is the ultimate daily driver imo.
      02-13-2020, 01:01 PM   #13
lnxguy
357
Drives: 2009 335D
Thermostat
Glow plug module
Injectors
Vacuum lines
RDC module
SCR system
I'd remove injectors off this list. Not a common problem IMO.
'09 335D
Nyc Dito112.50
      02-14-2020, 02:06 AM   #14
mefferso
44
Drives: 2010 335d
In 2014, I bought a 2010 335d and still have it. It had 30k miles back then and now I'm close to 150k miles. It's been as reliable as any Toyota or Ford Diesel i've ever owned.
For you, I think you can either buy one on the cheap and plan to put in some money and/or time to replace common wear items. Or you can buy one for $10k-$12k thats up to date on all maintenance. Check out the M57/N57 facebook group (https://www.facebook.com/groups/NABDOG/) I see for sale listings almost daily. You could also post a WTB thread there too.
      02-19-2020, 10:59 AM   #15
grotto
grotto's Avatar
10
Drives: 2002, 993, 335d
2011 BMW 335d  [0.00]
1976 BMW  [0.00]
1995 Porsche 911  [0.00]
I'm at 102k owned it since 2013 (2011 M sport) and only had carbon cleaning and def tank replacement under warranty at around 50k. Replaced all rotors and pads once, shocks and struts (Sach's), glow plug module. Car has been beyond reliable, smooth, luxury, great mileage and power/efficiency on long distance drives. Will replace motor mounts (feel vibration and squeal while turning left). Using T6 and Startron diesel additive.. Most reliable BMW and I've had since1990 - owned M3's, M5's, 325is, 545i, 2002. Used 335d these days is beyond cheap even if you have to fix few things considering price of new cars and what you get. E90 still old BMW feel.
