01-30-2020, 01:27 PM | #1 |
47
Rep 163
Drivetrain Malfunction
Anyone ever get this error?
Drivetrain Malfunction Drive Moderately Maximum Drivetrain Output not available I've had it one time before a few months ago. Googling says this is caused by a cylinder misfire. Car went limp mode when I was driving on the highway. I restarted my car however and it seemed to go away and the car was fine. Today it happened again and both cases happened under moderate ~30% acceleration not WOT. However, it the error went away and the car drove fine when I restarted. Any ideas on what it could be? I am running the JB4 MHD BEF setup with catless downpipe. I've tried googling and it seems like just about anything could be the problem. I am thinking it could be the tune or maybe sparkplugs. Thoughts? Last edited by baldeagleman; 01-30-2020 at 01:40 PM.. |
01-30-2020, 01:53 PM | #2 | |
554
Rep 686
Drives: Your mom crazy
Garage List 2020 BMW M340i CURRENT [10.00]
2003 BMW 330i RIP [10.00] 2011 BMW 335i SOLD [10.00] 2016 BMW 340i SOLD [10.00] 2020 BMW X3M RIP [10.00] |
2020 M340i
DAW UF-X; Wagner intake manifold/port injection; ID1050xds; Precision Raceworks St2.5 LPFP ECUTEK; Wedge Performance E70 tune KW V2; BC Forged EH173 |
01-30-2020, 02:09 PM | #3 | |
47
Rep 163
01-30-2020, 04:33 PM | #4 |
12
Rep 76
I bet if you used your JB4 and scanned it, is the code it tripped 1F053C? Several people have had it with the JB4. It's related to the loss of traction suddenly and the car freaking out. Terry from N54 recommended lowering boost in first and second gear. It seems to work.
This has happened to me several times until I lowered the boost as they recommended. Terry from N54 claims that this sensor was disabled with a BEF, so I'm curious if its the same one. |
01-30-2020, 04:58 PM | #6 | |
47
Rep 163
01-30-2020, 06:02 PM | #7 |
Built Motor F30 340i
405
Rep 257
JB4 is notorious for causing drivetrain malfunctions. I've yet to get one with MHD.
Also to read codes just go to "Codes" tab on the JB4 app and read them, it'll give you the option to clear them.
Supr3me554.00 |
01-30-2020, 06:39 PM | #8 |
554
Rep 686
Bump- I had JB4 installed at the time when both codes were thrown. None since on MHD.
2020 M340i
01-31-2020, 01:31 PM | #9 |
47
Rep 163
Does the JB4 still need to be plugged into my car or can I unplug it and plug it into my computer? Is there some type of internal storage it has to keep codes?
01-31-2020, 04:07 PM | #10 |
12
Rep 76
I had the Bluetooth module with the JB4, so I can just connect from my phone and see the codes and change the maps. If you don't have that, maybe you can with the MHD App, if you had the BEF.
01-31-2020, 06:01 PM | #11 | |
809
Rep 1,372
Used to get this with the JB4 once in awhile. Hasn't happened since I pulled the JB4 and flashed 13k miles ago.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
440MIA24.00 |
02-01-2020, 02:08 AM | #12 |
Rep 28
I used to get the same code once about two years ago while the car is bone stock. That night I parked my car into the garage and this code popped up. Restarted the car and the code was gone. No clue what's going on there and brought the car to the dealership the next weekend and they said there was nothing. Never saw that code again since then except during the bm3 flash time.
02-05-2020, 06:21 AM | #13 |
Cheapskate
4450
Rep 4,995
Nobody can tell you what it is. It's the equivalent of a check engine light. Scan for codes and/or run logs to see if anything is wrong.
