The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Anyone from Colorado - deleted
      01-22-2020, 05:17 PM   #1
007_e350
007_e350's Avatar
217
Drives: 335i 2008 MHD'd / x5d E70
hey guys, I'm curious how CO treats alphabet soup removal, if you reside in CO and are deleted pls PM
enjoy in good health!
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      01-22-2020, 06:10 PM   #2
Chaulklet
Drives: 330i zhp
This would be a great sticky thread for all states...I'm curious for delaware as well and if they scan for readiness or just CEL on/off.
      01-23-2020, 11:38 AM   #3
Spyro235
260
Drives: '10 X5D, '04 330i ZHP
This is stuff that's normally easily googlable.
As far as delaware, I googled and in 10 seconds, determined that diesel vehicles newer than 1997 must pass the obd-II test. That'd defined above, on the DMV page, as
On-Board Diagnostic (OBDII) - OBD locationThere are two steps in the OBD II inspection. With the key on and the engine off, the inspector confirms that the MIL is functional. The inspector connects the inspection tool to the OBD II system to check the status of the system. The following is a typical OBD II connector. This test takes approximately 2 minutes to complete. The test checks for trouble codes and monitor readiness. If you have recently replaced your battery the vehicle's monitors will not be ready causing the vehicle to fail. Drive the vehicle for several days to reset the monitors prior to DMV testing. The OBDII test method will replace the Division's tailpipe test (and pressure test) for 1996 and new gasoline powered vehicles and 1997 and new diesel powered vehicles with MGVWR less than 8,500 pounds registered in New Castle County and Kent County.
So... they will check OB2 codes, and readiness codes are included in that. They will also cycle your ignition on and off to see that the check engine light come on, to make sure you didn't just remove the bulb or something.
Daily/ Tow: 2010 X5 35D - 326k, Deleted w/DUDMD Stage 2, Sutphin Trans tune, Comfort seat retrofit
Fun car: 2004 ZHP 6mt - 256k miles, z4m FCAB, stock. Drift car: 2001 330i for sale
      01-23-2020, 11:41 AM   #4
Spyro235
260
CO dmv site states that they are dyno tested every year. So... you're probably porked, as far as I can tell. dyno tests means they likely sniff your tailpipe, and no deleted diesel will ever pass that.
Good luck to you, I hope you find a CO resident with better answers for you!
      01-25-2020, 09:09 AM   #5
335dlci
277
Drives: 335d
Colorado local here....
